Hi.
I can´t use the function delay_ms and delay_us with any values.
I can´t use delay_us(1000) , the delay is lower than 1000 and i can´t use delay_ms(5).
are there limits for delay?
SherpaDoug
Posted: Fri Jan 25, 2008 8:30 am
It should take any 16 bit constant, or 8 bit variable.
Give us a short complete program to demonstrate the problem. Note your compiler version. _________________ The search for better is endless. Instead simply find very good and get the job done.
alex Guest
Posted: Fri Jan 25, 2008 4:47 pm
I´m out of my work now, so I will take it Monday. sorry.
I would like to simulate the CCS source in Proteus, it is possible?
Are there a tutorial in the net?
thanks
