millisecond using timer2
X!ndY M@riE
PostPosted: Thu Jan 24, 2008 10:13 pm     Reply with quote
hi guys.. im trying to learn different things about timers. i have already generated a seconds counter using timer0. Now im planning to create a seconds counter using milliseconds with timer2. its like im counting in milliseconds then everytime i reach 1000 it will count 1 second. but my code seems to be counting so fast. can anybody help me figure out whats wrong with my code? here it is.. thanks everyone.
#include<16f877.h>
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
byte millisecond;
byte second;
#int_timer2
void time_isr()
   if (++millisecond==1000)
      {millisecond = 0;
      ++second;
      printf("%d\n\r",second);
   setup_timer_2 ( T2_DIV_BY_4, 250, 5);
   printf("Press any key");
   getch();
   while (1){
PostPosted: Fri Jan 25, 2008 12:43 am     Reply with quote
byte millisecond;
byte second;
#int_timer2
void time_isr()
{millisecond = 0;
++second;
What's the largest value a byte variable can hold ?
What data type should you use to declare 'millisecond', so that it
can hold a value of 1000 ?
PostPosted: Fri Jan 25, 2008 2:14 am     Reply with quote
yah.. the moment i clicked the submit button, thats when i realized what is wrong with my code.. it was so stupid of me.. thanks anyway..
