GET_TRIS_A() command
stewc
PostPosted: Thu Jan 24, 2008 10:43 am     Reply with quote
Hi
Is the command
variable = GET_TRIS_B();
valid for PIC12F509?
I get this error when I compile
Undefined identifier -- get_tris_b
PostPosted: Thu Jan 24, 2008 11:07 am     Reply with quote
Look in the I/O Port section of the 12F509 data sheet. There's a
schematic of a circuit for an i/o pin. Compare it to the 16F877
data sheet. You'll notice that the 12F509 doesn't have a tri-state
buffer going from the TRIS latch to the internal data bus. But the
16F877 does have it. Therefore you can't read the TRIS latch on
a 12F509. That's how you find the answer to this question.
Actually, also on that page in the 12F509 data sheet, it says this:
The TRIS registers are “write-only”
stewc
PostPosted: Thu Jan 24, 2008 12:43 pm     Reply with quote
I got confused because the user manual says
Availability: All devices
Thanks you
Heath
PostPosted: Thu Jan 24, 2008 1:14 pm     Reply with quote
Datasheet always beats the ccs user's manual. Smile
