Ds1307 12-hour format.
micr_brain
PostPosted: Thu Jan 24, 2008 8:29 am     Reply with quote
Dear Electronics friends.
I want to display on lcd the current date and the time with 12-hour format.
Please tell me , how set 12-hour format mode.
Thanks micr_brain.
Humberto
PostPosted: Thu Jan 24, 2008 9:13 am     Reply with quote
http://datasheets.maxim-ic.com/en/ds/DS1307.pdf
From page 8:
"The DS1307 can be run in either 12-hour or 24-hour mode. Bit 6 of the hours register
is defined as the 12-hour or 24-hour mode-select bit.
When high, the 12-hour mode is selected.
In the 12-hour mode, bit 5 is the AM/PM bit with logic high being PM.
In the 24-hour mode, bit 5 is the second 10-hour bit (20 to 23 hours).
The hours value must be re-entered whenever the 12/24-hour mode bit is changed."
Humberto
micr_brain
PostPosted: Sat Jan 26, 2008 8:52 pm     Reply with quote
Thanks Humberto.
Please tell me how enable 12-hour format with this file
micro_brain
#include <16F876a.h>
#include <ds1307.h>
#fuses NOWDT,XT, PUT, NOPROTECT, BROWNOUT ,NODEBUG ,NOLVP
#use rs232(baud=9600,parity=N,xmit=PIN_A0,rcv=PIN_A1,bits=8)
#zero_ram
int DATE,MTH,YR,HR,MT,SECDS,DOW;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_vref(FALSE);
   ds1307_init();
   while(1){
      ds1307_get_time(HR,MT,SECDS);
      ds1307_get_date(DATE,MTH,YR,DOW);
      printf("\rTime %2D:%02D:%02D",HR,MT,SECDS);
      printf("      Date  %2D/%02D/%02D",DATE,MTH,YR);
      if(!input(PIN_C0 ))
         ds1307_set_date_time(28,1,8,2,11,50,0);  // Time 11:50:00      Date   28/01/08
this is 24-hour format. working Perfectly.
but I want to change this code to 12-hour format and (AM/PM) indication
Please help me.
ds1307.h
///                               DS1307.C                                   ///
///                     Driver for Real Time Clock                           ///
/// ds1307_init() - Enable oscillator without clearing the seconds register -///
///                 used when PIC loses power and DS1307 run from 3V BAT     ///
///               - Disable squarewave output                                ///
/// ds1307_set_date_time(day,mth,year,dow,hour,min,sec)  Set the date/time   ///
/// ds1307_get_date(day,mth,year,dow)               Get the date             ///
/// ds1307_get_time(hr,min,sec)                     Get the time             ///
#define RTC_SDA  PIN_C4
#define RTC_SCL  PIN_C3
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
BYTE bin2bcd(BYTE binary_value);
BYTE bcd2bin(BYTE bcd_value);
void ds1307_init(void)
   BYTE seconds = 0;
   i2c_start();
   i2c_write(0xD0);      // WR to RTC
   i2c_write(0x00);      // REG 0
   i2c_start();
   i2c_write(0xD1);      // RD from RTC
   seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
   i2c_stop();
   seconds &= 0x7F;
   delay_us(3);
   i2c_start();
   i2c_write(bin2bcd(seconds));     // Start oscillator with current "seconds value
   i2c_start();
   i2c_write(0x07);      // Control Register
   i2c_write(0x80);     // Disable squarewave output pin
   i2c_stop();
void ds1307_set_date_time(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec)
  sec &= 0x7F;
  hr &= 0x3F;
  i2c_start();
  i2c_write(0xD0);            // I2C write address
  i2c_write(0x00);            // Start at REG 0 - Seconds
  i2c_write(bin2bcd(sec));      // REG 0
  i2c_write(bin2bcd(min));      // REG 1
  i2c_write(bin2bcd(hr));      // REG 2
  i2c_write(bin2bcd(dow));      // REG 3
  i2c_write(bin2bcd(day));      // REG 4
  i2c_write(bin2bcd(mth));      // REG 5
  i2c_write(bin2bcd(year));      // REG 6
  i2c_write(0x80);            // REG 7 - Disable squarewave output pin
  i2c_stop();
void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow)
  i2c_start();
  i2c_write(0xD0);
  i2c_write(0x03);            // Start at REG 3 - Day of week
  i2c_start();
  i2c_write(0xD1);
  dow  = bcd2bin(i2c_read() & 0x7f);   // REG 3
  day  = bcd2bin(i2c_read() & 0x3f);   // REG 4
  mth  = bcd2bin(i2c_read() & 0x1f);   // REG 5
  year = bcd2bin(i2c_read(0));            // REG 6
  i2c_stop();
void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec)
  i2c_start();
  i2c_write(0xD0);
  i2c_start();
  i2c_write(0xD1);
  sec = bcd2bin(i2c_read() & 0x7f);
  min = bcd2bin(i2c_read() & 0x7f);
  hr  = bcd2bin(i2c_read(0) & 0x3f);
  i2c_stop();
  BYTE temp;
  BYTE retval;
  temp = binary_value;
  retval = 0;
    // Get the tens digit by doing multiple subtraction
    // of 10 from the binary value.
    if(temp >= 10)
      temp -= 10;
      retval += 0x10;
    else // Get the ones digit by adding the remainder.
      retval += temp;
  return(retval);
// Input range - 00 to 99.
  BYTE temp;
  temp = bcd_value;
  // Shifting upper digit right by 1 is same as multiplying by 8.
  temp >>= 1;
  // Isolate the bits for the upper digit.
  temp &= 0x78;
  // Now return: (Tens * 8) + (Tens * 2) + Ones
  return(temp + (temp >> 2) + (bcd_value & 0x0f));
