I2C Slave problems with a PIC18F6622
SB
PostPosted: Tue Jan 22, 2008 11:37 am     Reply with quote
I am using the Ex_slave.c example on a Pic18F6622 with a Diolan USB to I2C interface adapter.
I am unable to read from the Pic, the Diolan times out and reports that the Slave has dropped the SDA and SCL lines.
I have tried using the second I2C on the pic with the same results.
I can program some DAC's which I have on the second I2c via the Diolan adapter so I am pretty sure that my hardware is ok.
I have tried the same code with a Pic16F88 and the Diolan adapter and it works without any problems.
Has anyone used the 18F6622 as an I2C slave?
(I am using PCWH V3.234)
#include <18F6622.h>
#device adc=10
#FUSES NOWDT
#FUSES WDT128
#FUSES INTRC_IO
#FUSES NOPROTECT
#FUSES IESO
#FUSES BROWNOUT
#FUSES BORV25
#FUSES NOPUT
#FUSES NOCPD
#FUSES STVREN
#FUSES NODEBUG
#FUSES NOLVP
#FUSES NOWRT
#FUSES NOCPB
#FUSES NOEBTRB
#FUSES NOEBTR
#FUSES NOWRTD
#FUSES NOWRTC
#FUSES NOWRTB
#FUSES FCMEN
#FUSES LPT1OSC
#FUSES NOMCLR
#FUSES NOXINST
#FUSES BBSIZ1K
#use delay(clock=8000000)
#use     i2c(Slave,sda=PIN_C4,scl=PIN_C3,address=0xa0,force_hw)
BYTE address;
BYTE buffer[0x10] = {1,2,3,4,5,6,7,8,9,0};
#INT_SSP
void ssp_interupt ()
   int8 incoming;
   int8 state;
   state = i2c_isr_state();
   if(state < 0x80)                     //Master is sending data
      incoming = i2c_read();
      if(state == 1)                     //First received byte is address
         address = incoming;
      if(state == 2)                     //Second received byte is data
         buffer[address] = incoming;
   if(state == 0x80)                     //Master is requesting data
     i2c_write(buffer[address]);
   setup_adc_ports(AN0_TO_AN1|VSS_VDD);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);
   setup_wdt(WDT_OFF);
   setup_timer_1(T1_DISABLED);
   set_timer1(64535);
   setup_vref(FALSE);
   enable_interrupts(INT_SSP);
     restart_wdt();
SB
PostPosted: Thu Jan 24, 2008 8:54 am     Reply with quote
Just in case anyone is interested but I managed to fix my problem.
The i2c_isr_state() routine checks bit 0 of the SSP1BUF to see if it is a read or a write.
For some reason in the chip you have to look at bit 2 of SSP1STAT to see if it is a read or write.
If anyone know why this is the case I would be interested to know.
So using someones code from this forum I modified it slightly to look at the SSP1STAT.2 instead of SSP1BUF.0
#byte SSP1STAT = 0xFC7
#bit DA_BIT = SSP1STAT.5
#bit RW_BIT = SSP1STAT.2
#inline
int8 my_i2c_isr_state(void)
   static int8 i2c_state = 0x03;
   int8 retval;
   if(!DA_BIT)          // If address byte was received
      i2c_state = 0;    // Then clear state.
      if(RW_BIT)        // If it is a Read address
         bit_set(i2c_state, 7);  // Then set bit 7 of state.
   retval = i2c_state;
   i2c_state++;
   return(retval);
#INT_SSP
   int8 incoming;
   int8 state;
   state = my_i2c_isr_state();
         address = incoming;
