could't write to LCD
pokiko
PostPosted: Wed Jan 16, 2008 8:48 am     Reply with quote
Hi to all and thanks for such a great forum. I wrote the below code, but i couldn't able to write it to LCD. The problem may be with the code. I used the Flex_LCD at this forum. Can anyone tell me about the problem please?
PIN configurations of LCD.
#define LCD_DB4 PIN_C4
#define LCD_DB5 PIN_C5
#define LCD_DB6 PIN_C6
#define LCD_DB7 PIN_C7
#define LCD_E PIN_C3
#define LCD_RS PIN_C0
//#define LCD_RW PIN_A2
//#define USE_LCD_RW 1
LCd is an h44780 compatible. Pin3 is connected to +5v over 10k and to GND over 330 ohm. R/W is connected to GND. LCD gets power but i can't see anything.
#include <18F2520.h>
#device  adc=10
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
//#include <stdio.h>
#include  "flex_LCD.c"
#use fast_io(a)
#use fast_io(b)
//#use fast_io(c)
#define     BUTON_UP       !input(PIN_B4)
#define     BUTON_DOWN     !input(PIN_B5)
#define     BUTON_ENTER    !input(PIN_B6)
#define     BUTON_BREAK    !input(PIN_B7)
#define     MIN_AMPER   1
#define     MAX_AMPER   49
#define     MIN_VOLTAGE  0
#define     MAX_VOLTAGE  30
#define     MIN_CCP_1   12000
#define     MAX_CCP_1   24500
#define     MIN_CCP_2   37000
#define     MAX_CCP_2   49500
//some code in here
unsigned int akim=0;
unsigned int   gerilim=0;
unsigned int16 ADC_TO_BE;
unsigned int16 Total_ADC_I;
unsigned int16 Total_ADC_V;
unsigned int16 READED_I;
unsigned int16 READED_V;
void init_MCU();
unsigned int16 ADC_Compute_I(unsigned int16);
unsigned int16 ADC_Compute_V(unsigned int16);
void main(){
      int   modeSelect=0;
      init_MCU();
      printf(lcd_putc,"\f UP-Akım modu\n");
      printf(lcd_putc,"\f DOWN-Gerilim modu");
      if(BUTON_UP){
         modeSelect=1;//AKIM MODU
         delay_ms(20);
      if(BUTON_DOWN){
         modeSelect=2;  //GERİLİM MODU
         delay_ms(20);
      if(modeSelect!=0){
         if(modeSelect==1){
            set_adc_channel(0);
            delay_us(20);
            ccp_1=65535; //ensures that no false CCP interrupt occurs!
            ccp_2=65535;
            set_timer1(0);
            set_timer3(0);
            enable_interrupts( GLOBAL );
            while(1){
               printf(lcd_putc,"\fI_set=%d\n",akim);
               if (BUTON_UP){
                  akim++;
                  delay_ms(20);
                  if(akim>MAX_AMPER){
                     akim=50;
               if(BUTON_DOWN){
                  akim--;
                  delay_ms(20);
                  if(akim<MIN_AMPER){
                     akim=0;
               Total_ADC_I=ADC_Compute_I(akim);
               READED_I=read_adc();
               if (READED_I>Total_ADC_I){
                  CCP_1++;
                  CCP_2=CCP_1+25000;
                     if(CCP_1>MAX_CCP_1)
                        CCP_1=MAX_CCP_1;
                        CCP_2=CCP_1+25000;
               if (READED_I<Total_ADC_I){
                  CCP_1--;
                  CCP_2=CCP_1+25000;
                     if(CCP_1<MIN_CCP_1)
                        CCP_1=MIN_CCP_1;
                        CCP_2=CCP_1+25000;
         if(modeSelect==2){
          //some code in here
unsigned int16 ADC_Compute_I(unsigned int16 ampere)
   unsigned int16   kademe;
   kademe=(unsigned int16)(ampere*18,618181818);
   return   kademe;
void init_MCU(){
setup_spi(SPI_SS_DISABLED);
            ext_int_edge(L_TO_H);
            output_low( PIN_A5 );
            setup_ccp1( CCP_COMPARE_INT );
            setup_CCP2( CCP_COMPARE_INT );
            enable_interrupts( INT_EXT );
            enable_interrupts( INT_CCP1 );
            enable_interrupts( INT_CCP2 );
            enable_interrupts( RTCC_OFF );
            setup_timer_1( T1_INTERNAL |T1_DIV_BY_2 );/
            setup_timer_3 (T3_INTERNAL | T3_DIV_BY_2);
            setup_adc_ports(ALL_ANALOG);
            set_tris_a(0b00011001);
            set_tris_b(0b11110001);
            delay_ms(20);
            lcd_init();
            delay_ms(1500);
           ccp_1=65535;
           ccp_2=65535;
            set_timer1(0);
            set_timer3(0);
PostPosted: Wed Jan 16, 2008 12:37 pm     Reply with quote
Your test program is too complicated. Try this program instead:
#include <18F2520.H>
#use delay(clock = 20000000)
#include "flex_lcd.c"
lcd_init();
lcd_putc("\fHello World\n");
lcd_putc("Line Number 2");
pokiko
PostPosted: Thu Jan 17, 2008 9:51 am     Reply with quote
I tried the code above. Still there is no change. Some data goes to LCD when i look with a scope, but I can't see even black squares. Already nothing.
could there be a problem with port c? Exclamation
Ramyses
PostPosted: Fri Jan 18, 2008 5:43 pm     Reply with quote
O problema pode ser a falta de delays na bliblioteca flex_LCD. Eu tinha esse mesmo problema, mas inseri alguns delays na biblioteca e resolveu.
Os sinais são muito rápidos para o LCD entender, por isso os delays
SDS
Translation:
The problem can be the lack of delays in the library flex_LCD. I had this exactly problem, but I inserted some delays in the code and fixed it.
Franck26
PostPosted: Sat Jan 19, 2008 7:36 am     Reply with quote
Is the contrast of your LCD is properly set?
Franck.
pokiko
thank you
PostPosted: Wed Jan 23, 2008 10:32 am     Reply with quote
i have eliminated the problem. It was about the LCD. thank you Franck26 and Ramyses.
