Only displaying 8 places on a 1x16 LCD
agompert
PostPosted: Tue Jan 22, 2008 4:34 pm     Reply with quote
I'm new to C programing and am having a problem with displaying on a LCD. I am using a 1X16 line LCD. in 4 bit mode, and using the LCD.C
include file. Only the first 8 digit are displaying on the left. It only displays "Hello Wo " and is not displaying the whole thing "Hello
World". It is only displaying 8 character on the left and not the whole 16 characters.
Here is my code, I have included the LCD.C include file where I think the problem is, below
Please Help
    setup_adc_ports(NO_ANALOGS);
    setup_adc(ADC_OFF);
    setup_spi(SPI_SS_DISABLED);
    setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
    // TODO: USER CODE!!
    lcd_init();
    set_timer1(0);
    lcd_putc("Hello World");
//////////////////////LCD.C include file/////////////////////////
#define use_portb_lcd TRUE
struct lcd_pin_map {                 // This structure is overlayed
           BOOLEAN enable;           // on to an I/O port to gain
           BOOLEAN rs;               // access to the LCD pins.
           BOOLEAN rw;               // The bits are allocated from
           BOOLEAN unused;           // low order up.  ENABLE will
           int     data : 4;         // be pin B0.
        } lcd;
#if defined use_portb_lcd
   //#locate lcd = getenv("sfr:PORTB")    // This puts the entire structure over the port
   #ifdef __pch__
    #locate lcd = 0xf81
   #else
    #locate lcd = 6
   #define set_tris_lcd(x) set_tris_b(x)
#else
   //#locate lcd = getenv("sfr:PORTD")    // This puts the entire structure over the port
   #ifdef __pch__
    #locate lcd = 0xf83
   #else
    #locate lcd = 8
   #define set_tris_lcd(x) set_tris_d(x)
#ifndef lcd_type
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcd_read_byte() {
      BYTE low,high;
      set_tris_lcd(LCD_READ);
      lcd.rw = 1;
      delay_cycles(1);
      lcd.enable = 1;
      delay_cycles(1);
      high = lcd.data;
      lcd.enable = 0;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(1);
      low = lcd.data;
      lcd.enable = 0;
      set_tris_lcd(LCD_WRITE);
      return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
      lcd.data = n;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(2);
      lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
      lcd.rs = 0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd.rs = address;
      delay_cycles(1);
      lcd.rw = 0;
      delay_cycles(1);
      lcd.enable = 0;
      lcd_send_nibble(n >> 4);
      lcd_send_nibble(n & 0xf);
void lcd_init() {
    BYTE i;
    lcd.rs = 0;
    lcd.rw = 0;
    lcd.enable = 0;
    delay_ms(15);
    for(i=1;i<=3;++i) {
       lcd_send_nibble(3);
       delay_ms(5);
    lcd_send_nibble(2);
    for(i=0;i<=3;++i)
       lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
   BYTE address;
   if(y!=1)
     address=lcd_line_two;
     address=0;
   address+=x-1;
   lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   delay_ms(2);
     case '\n'   : lcd_gotoxy(1,2);        break;
     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
char lcd_getc( BYTE x, BYTE y) {
   char value;
    lcd_gotoxy(x,y);
    while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
    lcd.rs=1;
    value = lcd_read_byte();
    lcd.rs=0;
    return(value);
PostPosted: Tue Jan 22, 2008 4:44 pm     Reply with quote
You don't have to start a new topic every time you have a question.
You already have a topic on 1x16 LCDs here:
http://www.ccsinfo.com/forum/viewtopic.php?t=33400
You should ask all questions on 1x16 LCDs in the same topic.
A 16x1 LCD requires a special driver. The normal LCD.c driver from
CCS will not work. Here is a 16x1 driver.
http://www.ccsinfo.com/forum/viewtopic.php?t=30964
If you have any questions, post them in this same topic.
