16F690-delay issue
nmeyer
16F690-delay issue
PostPosted: Tue Jan 22, 2008 12:00 pm     Reply with quote
I am trying to write a simple program to have 6 outputs that i pull low or let float high. I have started to write the program and all i am doing is toggleing one of the outputs low and float. However, when i run the program the pin is never pulled low (100K pull up to 3.3v). I am not sure what i have set up wrong that is causing the issue. Can anyone see if they can catch my mistake? I am using the internal rc at 2 mhz and would like to go lower.
Compiler version 4.062
#include <16F690.h>
#device adc=10
//#priority ssp,rtcc,ext
#use delay(clock=2000000, RESTART_WDT)
#fuses WDT,INTRC_IO, PUT, MCLR, NOBROWNOUT, NOCPD, NOPROTECT
#use i2c(MASTER,slow,sda=PIN_C4,scl=PIN_C6)
#include <math.h>
#use fast_io(A)
#define  sw_in    PIN_A2            //interrupt pin
#define  LED4     PIN_A4            //60% led, green
#define  LED2     PIN_A5            //10-20% led, yellow
#use fast_io(B)
#define SMBD      PIN_B4            //smbus data external
#define LCD_EN    PIN_B5            //100% led, green
#define SMBC      PIN_B6            //smbus clock external
#use fast_io(C)
//#define LCD_EN    PIN_C0            //80% led, green
#define BAR1      PIN_C3
#define BAR2      PIN_C4            //smbus data, internal
#define BAR3      PIN_C5            //40% led, green
#define BAR4      PIN_C6            //smbus clock, internal
#define BAR5      PIN_C7            //10% or less led, red
//#define INTS_PER_SECOND  30
#define INTS_PER_SECOND  61  //244
#BYTE   SSPCON1 = 0x14
int   address,lsb_ch_crnt,lsb_percent,msb_status;
char  i,int_count,bus_free,fault,change_current,chg_term=0,set=0;
int   lsb_current,msb_current,count=0,msb,lsb_volt,lsb_status;
int   lsb_percent_send,lsb_temp_send,lsb_volt_send,lsb_ch_crnt_send;
int   lsb_status_send,msb_status_send;
long  time1,seconds,voltage,percent,status,ch_current;
long  time_cnt=0,value,loop;
int32  new_val;
signed long  current,temperature;
signed int   i2c_temp,lsb_temp,lsb;
#int_rtcc
void clock_isr(void)
   if(--int_count==0)                     //decrement counter until 0
      ++seconds;                          //count up seconds
      int_count=INTS_PER_SECOND;          //reset counter
      if (seconds>=65000)
         seconds=65000;
void read_sm_percent (void)
i2c_start();                        //read capacity
i2c_write(0x16);
i2c_write(0x0D);                    //relative state of charge
i2c_start();
i2c_write(0x17);                    //tell battery to write data
percent=i2c_read(0);                //read the data
i2c_stop();
output_float(SMBC);                  //release data line
output_float(SMBD);                  //release clock line
lsb_percent=make8(percent,0);
void sm_free (void)
 while (count<=25)
         if ((input(SMBC))&&(input(SMBD)))
            bus_free=1;
            bus_free=0;
            count=26;
         delay_us(3);
         count=count+1;
      count=0;
   output_float(LCD_EN);                     //turn led off
   output_float(BAR1);                     //turn led off
   output_float(BAR2);                     //turn led off
   output_float(BAR3);                     //turn led off
   output_float(BAR4);                     //turn led off
   output_float(BAR5);                     //turn led off
   setup_oscillator(osc_2mhz);
   setup_adc_ports(NO_ANALOGS);
   setup_wdt(WDT_ON|WDT_36MS);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);
   set_rtcc(0);
   enable_interrupts(INT_RTCC);
   setup_timer_1(T1_DISABLED);
   set_tris_a(0b00000100);
   set_tris_b(0b01000000);
   set_tris_c(0b00000000);
   int_count=INTS_PER_SECOND;          //used for timer
   seconds=0;                          //clear out variable
   time1=1;                        //counter for time,30 seconds
   loop=0;
   //percent=0;
   while (TRUE)
      output_float(bar5);
      delay_ms(33);
      output_low(bar5);
      delay_ms(33);
PostPosted: Tue Jan 22, 2008 12:46 pm     Reply with quote
I am toggling one of the outputs low and float. However, when I run the
program the pin is never pulled low.
You're using Fast I/O mode. In that mode, the CCS pin i/o functions
in your program only do this:
output_float() changes the TRIS register.
output_low() changes the latch register.
So even though you change the latch register, it doesn't have any
effect on the output of the pin, because the TRIS is still set to make
the pin be an input.
You can see this in the list file. I've removed the calls to delay_ms()
for clarity:
... while (TRUE)
...  output_float(SMBC);      // release data line
00B8:  BSF    STATUS.RP0
00B9:  BSF    TRISB.6
...  output_float(SMBD);     // release clock line
00BA:  BSF    TRISB.4
...  output_float(bar5);
00BB:  BSF    TRISC.7    // Set TRIS on pin C7 to input
...  output_low(bar5);
00BC:  BCF    STATUS.RP0
00BD:  BCF    PORTC.7   // Set Port Register bit for pin C7 to 0.
                        // Note that TRIS remains set to an input.
