I have a problem when using port A on a PIC16F884. Reading this port always returns a zero. I use a relay on the board to indicate the state. The input to port A is a 6 position DIP switch and a 3 position toggle switch. The toggle is on A0,A1 and the DIP switch is on the rest. They are all pulled up to +5V with 10k resistors. Any help would be greatly appreciated.
I have the PUMP_MODE, SPLX_DPLX, etc #define'd to individual port A pins in the following code.
It looks like answered my own question. I had to clear the ANSEL register (0x188) since it appears that the ADC setup functions of CCS neglect to do so.
