I was wondering if someone could give me a little direction on how to convert a 16 bit binary # into a form I can output to the lcd_putc() function which is in the lcd.c include file? Or maybe which function should I use to do this conversion ?
Posted: Mon Jan 21, 2008 10:48 pm
Do it with printf. In CCS, printf has a special feature where its output
can be re-directed to another function. You can re-direct it to the
lcd_putc() function and it will be displayed on the LCD. Printf will do
the conversion from an integer to ASCII for you.
