Problem with MCLR on 12F509
GUest1
PostPosted: Sat Jan 19, 2008 12:19 pm     Reply with quote
Hi
I have written this small demo program
#include "12F509.h"
//#use fast_io(B)
#fuses INTRC,NOWDT,NOPROTECT,NOMCLR
#define set_options(value)   {#ASM         \
                              MOVLW  value \
                              OPTION       \
                              #ENDASM}
#define ON 1
#define OFF 0
#define FIRE   pin_b0      //ouput
#define ONOFF   pin_b3      //input
#define ADJUST   pin_b1      //input
#define LED      pin_b2      //output
#define DEBOUNCE_TIME 100   //20ms debounce time
#define ENABLEPULLUPS (0)
#define DISABLEPULLUPS (128)
unsigned char debounce_ONOFF (void);
            Initilisation
   boolean out = OFF;                  //The output bit
   boolean onoffbutton;                     //On Off button
      SETUP_TIMER_0(RTCC_DIV_1 | ENABLEPULLUPS);   //Work around to enable pullups
   set_options(0x80);                  // Allow use of GP2 for i/o
                            Main
      onoffbutton = debounce_ONOFF();         //read button
      out ^= 0x01;
      output_bit (FIRE,out);      //Toggle output
      output_bit (LED,out);      //Toggle output
unsigned char debounce_ONOFF ()
   if (!input(ONOFF))
         delay_ms(DEBOUNCE_TIME);
       if (!input(ONOFF)) return 1;
    return 0;
I would expect the LED to toggle at a rate of 100ms + 100 ms ( debounce time + delay_ms)
However when I run it toggles at 100ms
When I press my button (a switch to ground off GP3) the toggle time then becomes 200ms.
I was wondering if this is something to do with the MCLR function(GP3 alternate function) but I cant understand why it behaves like this.
PostPosted: Sat Jan 19, 2008 12:28 pm     Reply with quote
sorry, should read more easily
#include "12F509.h"
MOVLW value \
OPTION \
#ENDASM}
#define ON 1
#define OFF 0
Initilisation
Main
      out ^= 0x01;
   if (!input(ONOFF))
   return 0;
PostPosted: Sat Jan 19, 2008 12:45 pm     Reply with quote
The OPTION register controls the pre-scaler for TIMER0.
You have two functions that write to the OPTION register:
set_options(0x80);
Look at the .LST file (it's in your project directory). It shows the ASM
code generator by the compiler. You can see that both functions are
writing to the OPTION register, and that the set_options() function is
over-writing the value of 0x08 with a new value of 0x80. It's taking
the pre-scaler away from Timer0 and assigning it to the Watchdog Timer.
This is explained in the 12F509 data sheet, in the section on the OPTION
register.
.... SETUP_TIMER_0(RTCC_DIV_1 | ENABLEPULLUPS);
0003:  MOVLW  08
0004:  OPTION
.... set_options(0x80);
0005:  MOVLW  80
0006:  OPTION
The reason you originally added the set_options() function was because
you were not using the setup_timer_0() in your program, and you wanted
a way to set the OPTION register. But now, you have modified your
program to add a call to setup_timer_0(), which does configure the
OPTION register.
Solution: Delete the line that calls set_options(0x80). You don't need
it anymore. Or at least, comment it out, and add a note that it's not
needed as long as setup_timer_0() is being used.
Also, you could use a consistent screen name. Previously you were stewc
but now you're "guest1".
stewc
PostPosted: Sat Jan 19, 2008 1:09 pm     Reply with quote
Hi
Yes, that all makes sense. I included the line
set_options(0x80);
to enable pullups, I am not using the TMR0
I tried commenting out the line you said and it made no difference. Even tried it with the options set to 80, still the same.
It appears that when I pull GP3 to ground the program runs correctly - but this is undesirable as I have an input switch in GP3.
I could use another pin but I want to get the the bottom of it. I must have some fuses/settings wrong but I cant see where . AAARRGG!!
(username ok now)
PostPosted: Sat Jan 19, 2008 1:17 pm     Reply with quote
I can see that now. I jumped on the timer0 issue because I knew that
both of the functions were changing the OPTION register.
PostPosted: Sun Jan 20, 2008 12:01 am     Reply with quote
(debounce time + delay_ms). However when I run it toggles at 100ms.
I converted your program to run on a 16F877, and it runs exactly the
same way. That's the way it should run. There is a 100 ms delay in
the while() loop all the time. Optionally, there is another 100 ms
delay added to it if you hold down the pushbutton.
In your code below, you test the "ONOFF" pin to see if it's low.
If it is, then you execute the code inside the braces, which includes
the debounce delay.
if (!input(ONOFF))
return 0;
stewc
PostPosted: Sun Jan 20, 2008 5:44 am     Reply with quote
ah yes, i see that now. i thought it would always run the debounce routine but its in a conditional statement
thanks Very Happy
