18f4520 PWM
colourwheel
18f4520 PWM
PostPosted: Thu Jan 17, 2008 8:12 am     Reply with quote
i am a beginner and i hope to find out how PWM works. How it produce sounds or duty cycle. hope someone can help me with the programm thanks.
BLAH_BLAH
PostPosted: Thu Jan 17, 2008 9:46 am     Reply with quote
1) search the forum
2) look at the ex_pwm.c file in your examples directory
3) read the manual
4) read the datasheet
5) try writing the code. If it doesn't work, post your (very simple) code and ask specific questions.
1-4 aren't necessarily in the correct order, but 5 should be the last step you try! Wink
PostPosted: Thu Jan 17, 2008 12:10 pm     Reply with quote
See this post for a demo program:
http://www.ccsinfo.com/forum/viewtopic.php?t=17729&start=1
colourwheel
PostPosted: Fri Jan 18, 2008 8:14 am     Reply with quote
mine is pic18f4520 issit the same as the link u post there?
i need to produce a fire engine sound, is that possible? any sample programm?
colourwheel
PostPosted: Fri Jan 18, 2008 8:23 am     Reply with quote
#include<p18f4520.h>
TRISC=0b11111011;
T2CON=0b00000101;
PR2=249;
CCPR1L=0B1111101;
CCP1COB=0B00001111;
i only have sounds coming out but it does no sound like a fire engine sound? how do i edit it to make it sound more like it?
PostPosted: Fri Jan 18, 2008 12:00 pm     Reply with quote
You should always tell us your overall purpose in your first post.
Put it in the title of your post.
Your purpose is to make music or play a simple tune with the PIC.
CCS has an example file for this. It's in this directory:
c:\Program Files\picc\Examples\Ex_Tones.c
Here's a post where someone needed help with it.
http://www.ccsinfo.com/forum/viewtopic.php?p=69356
Mark has posted a ring tone player int the Code Library:
http://www.ccsinfo.com/forum/viewtopic.php?t=22010
There are many other posts about playing sounds on the PIC.
Use the forum's search page to find them.
http://www.ccsinfo.com/forum/search.php
colourwheel
PostPosted: Sun Jan 20, 2008 12:37 am     Reply with quote
ok nex time i know what to put for the title and thanks for the help!!
