Low Frequency PWM
umka
Low Frequency PWM
PostPosted: Wed Jan 16, 2008 4:20 pm     Reply with quote
how does one get a low frequency?
i dont know how to get it to 50Hz i can get much less than 250Hz. do i have to go to a slower crystal? the adc sets the duty ratio.
#include <16F877a.h>
void main() {
   int value;
   setup_ccp1(CCP_PWM);
   setup_timer_2(T2_DIV_BY_16, 249, 5);
  setup_port_a(ALL_ANALOG);
  setup_adc(adc_clock_internal);
  set_adc_channel( 0 );
  while( TRUE ) {
    value=read_adc();
    set_pwm1_duty(value);
PostPosted: Wed Jan 16, 2008 5:18 pm     Reply with quote
You could use Timer0 (RTCC) to do software PWM. See this thread
for a link to the code.
http://www.ccsinfo.com/forum/viewtopic.php?t=30175
