PLL, HS fuse question !!
ELCouz
PostPosted: Mon Jan 14, 2008 8:58 pm     Reply with quote
Dear members,
I'm trying to get working my new project using the DsPIC30F6015 for the first time... but i ran into a problem
read the following image...
the microchip clearly state that I need to use the HS/2 or HS/3 fuse with PLL (12mhz crystal).
The 30F6015.h doesnt list the HS3 or HS2 thing with pll
see by yourself
//////// Fuses: XTL,HS,XT,XT_PLL4,XT_PLL8,XT_PLL16,ER_IO,ER,EC,EC_IO,EC_PLL4
//////// Fuses: EC_PLL8,EC_PLL16,LP,FRC,LPRC,PR,NOCKSFSM,CKSNOFSM,CKSFSM,WDT
//////// Fuses: NOWDT,WPSB1,WPSB2,WPSB3,WPSB4,WPSB5,WPSB6,WPSB7,WPSB8,WPSB9
//////// Fuses: WPSB10,WPSB11,WPSB12,WPSB13,WPSB14,WPSB15,WPSB16,WPSA1,WPSA8
//////// Fuses: WPSA64,WPSA512,NOPUT,PUT4,PUT16,PUT64,BROWNOUT,NOBROWNOUT
//////// Fuses: BORV20,BORV27,BORV42,BORV47,LPOL_HIGH,LPOL_LOW,HPOL_HIGH
//////// Fuses: HPOL_LOW,PWMPIN,NOPWMPIN,MCLR,NOMCLR,PROTECT,NOPROTECT,WRT
//////// Fuses: NOWRT,DEBUG,NODEBUG,COE,NOCOE,ICS0,ICS1,ICS2,ICS3
How i can run the dspic with a HS2 - HS3 with pll of 4x,8x or 16x?
XT is only for crystal up to 10 mhz , mine is 12mhz
Do i need to activate it manualy ... set a register to get it work ?
If yes , how ?
oh yeah, i'm using PCWHD 4.057
Many thanks !!! :D
Laurent
ELCouz
PostPosted: Wed Jan 16, 2008 2:26 am     Reply with quote
Image host is down reposted ...
Anyone ? Is it that difficult ?
Is it a bug in CCS ... Do i'm the only one using the CCS PCD compiler ??
Have a nice day !
Laurent[/url]
PostPosted: Wed Jan 16, 2008 3:31 am     Reply with quote
Try looking at the DsPIC/PIC24 comments at the head of this group....
Also there have been a couple of other threads about fuse problems with this compiler...
Your particular configuration is probably 'unique', among users, hence the lack of replies. There are other people using the PCD compiler, but how many want this particular lock combination, is probably low.
Post your question to CCS tech directly.
