Need help with i/o
agompert
Need help with i/o
PostPosted: Tue Jan 15, 2008 11:49 am     Reply with quote
I just started C programing and am trying to input from portc and then
output to portb but it's not looping,
Please help
#include "C:\test\main.h"
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
// TODO: USER CODE!!
set_tris_a(0xff); // set porta as inputs
set_tris_b(0x00); // set portb as outputs
set_tris_c(0xff); // set portc as inputs
output_b(0x00); // clear portb
input_c(); //
output_b(input_c()); //
PostPosted: Tue Jan 15, 2008 12:00 pm     Reply with quote
Please use a title for topic that describes the problem, such as
"Need help with i/o ports."
Don't just say "Need help".
PostPosted: Tue Jan 15, 2008 12:17 pm     Reply with quote
The code is not 'looping' because there is no loop command.
You have the following loop commands in C:
- while
- for
- do / while
An explanation of these commands is out of the scope of this forum, any C book or online course will handle that.
The tris setting commands are not needed as the compiler will handle this for you on every call to input or output data to a port.
The main part of your code could then look like:
int8 port_value;
while (TRUE)
  port_value = input_c();
  output_b( port_value );
