PIC's variable changing through PC
Goto page 1, 2  Next
arys
PostPosted: Tue Jan 15, 2008 3:09 am     Reply with quote
Hi, is it possible to do that? I never try it but it's in my mind. If can, how? or may be there are links for that. Actually I want to change
 delay_ms (x)[
through VB.
D-Kens
PostPosted: Tue Jan 15, 2008 3:44 am     Reply with quote
Assuming that you use port COM of your computer to connect to the RS232 of your PIC, you just have to scan for incoming characters (using int_rda or just kbhit() function), extract the desired value for the delay and copy it in a global variable or in EEPROM or wherever you want. Then you can use this value for anything in your programme... Wink
treitmey
PostPosted: Tue Jan 15, 2008 9:14 am     Reply with quote
Be careful tho, as it says in the help file
time - a variable 0-255 or a constant 0-65535
if you make it a variable you only can go 0-255
PostPosted: Tue Jan 15, 2008 11:31 am     Reply with quote
The V4 compiler improved this and allows the variable to be int16 (0 - 65535) as well.
arys
generate ~16khz pulses ???
PostPosted: Thu Feb 14, 2008 2:58 am     Reply with quote
Hi, thanks for the ideas. I've tried out. but its not work. when I send any 0-255 from VB it generates ~16kHz. then it doesnt want to change the second value (from VB). seems like int_rda doesnt work. here the codes
int8 x;
int8 j;
int8 y;
#int_rda
void rda_isr(void)
char c;
char string[10];
   c = getc(); // Get character from PC
   putc(c);    // Send it back to the pc
   strcpy(string,"c");
   x=atoi(String);
{    x=145;                            //initial value
 {   enable_interrupts(INT_RDA);
   for(y=0; y<=x; y++);{
   output_b(0b00000001);
   delay_us(10);
   for(j=0; j<=x; j++);{
   output_b(0b00000000);
   delay_us(10);
. I want to try get_string() function but I dont know how.
Embarassed
D-Kens
PostPosted: Thu Feb 14, 2008 3:04 am     Reply with quote
No matter what character you send, you copy the string "c" to your string variable, and not the character stored in c !
arys
see output/result
PostPosted: Tue Feb 19, 2008 3:39 am     Reply with quote
thanks D-Kens. I add few function. seems like it work.
   c_ptr=&c;
   strcpy(string,c_ptr);
   x=atoi(string);
but how can I see the result of x, since I only have CCS and MPLAB.
D-Kens
PostPosted: Tue Feb 19, 2008 4:05 am     Reply with quote
Don't you have the Serial Port Monitor in the "Tools" of your compiler, or Hyperterminal on your computer ? You can ask your main() to write to the console :
printf("x=%d\n\r", x) ;
For test purpose, you should also add a delay of a few seconds, else you'll flood the screen with lines and lines of "x=..." ! Wink
arys
PostPosted: Wed Feb 20, 2008 4:00 am     Reply with quote
many thanks. I try to use siow but nothing happen. what i did was, open siow --> open file **.c --> send hex number.
How to use siow correctly?
Wayne_
PostPosted: Wed Feb 20, 2008 7:18 am     Reply with quote
I have a major problem with your code.
c_ptr=&c;
x=atoi(string);
strcpy relies on NULL terminated strings. c is a single char in memory, there is no way of knowinf what value comes after it in memory. you seem to have been very lucky in that a null terminating character must come quite soon after the initial char otherwise the string array would overrun and you will corrupt memory.
you can either use strncpy(string, &c, 1) to copy just the 1 char or
string[0] = c;
string[1] = '\0';
and then use atoi(string).
The other option is to just do x = c - '0'; to retrieve the single digit.
A better method for what you are trying to do is:-
char buffer[10];
int index = 0;
#int_rda
void rda_isr(void)
  char c;
  c = getc();
  if (c == '\r') {
    buffer[index] = '\0';
    x = atoi(buffer);
    index = 0;
  } else
    buffer[index++] = c;
Note there are no checks to see if index becomes 10 or greater which would cause a buffer overrun.
casandralam
can receive integer from 0-255?working?
PostPosted: Sun Mar 02, 2008 7:09 am     Reply with quote
Wayne, do your code support for integer from 0-255?
Thanks..
Wayne_
PostPosted: Mon Mar 03, 2008 2:38 am     Reply with quote
The atoi function converts an ascii string of "0" to "255" to an integer so "0" becomes 0 and "255" becomes 255.
Integers in CCS are 8 bit so my code should work for a string value of 0 to 255.
casandralam
where is the output shown?
PostPosted: Tue Mar 04, 2008 3:10 am     Reply with quote
I'm a newbie.Please forgive me if you feel my question is stupid..
Which pin of the pic is the output?can i set myself for example port b0 as our output?
Then,
how can we observe the output?using lcd or 7 segment display?or any program can do for it?can you suggest me some method to do do?
Thanks you very much
casandralam
PostPosted: Tue Mar 04, 2008 3:16 am     Reply with quote
Why arys put x=145 as initial value in his main program?what does it means?
arys
PostPosted: Tue Mar 04, 2008 3:31 am     Reply with quote
yes, it's initial value. then i hope i can change the x value through pc.
--> actually we can each pin either become input or output. you can find it out in the CCS manual how to set IO.
-->i'm usually use ossciloscope or you can put the LED at the output.
Goto page 1, 2  Next
Page 1 of 2
