MAKE16() doesn't work !!!! please help
slyfox
PostPosted: Tue Jan 15, 2008 1:13 am     Reply with quote
Hello i use pcwhd 4.057 version and trying to use make16() :
int8 in1,in2;
int16 out1;
in1=0x0b;
in2=0xff;
out1=make16(in1,in2);
if i try to read out1 the result will be 0x00ff the higher byte will be always 00
why it doesn't work ?
please someone know if this is a problem from the compiler ?
thank you !
PostPosted: Tue Jan 15, 2008 1:20 am     Reply with quote
I installed vs. 4.057 and compiled the program shown below.
It displays the following output in the MPLAB simulator. It's correct.
out1 = 0bff
#include <16F877.H>
#fuses XT, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
int8 in1,in2;
int16 out1;
in1=0x0b;
in2=0xff;
printf("out1 = %lx \n\r", out1);
slyfox
PostPosted: Tue Jan 15, 2008 2:36 am     Reply with quote
Thank you !!!
my problem was not make16() but printf i see my error in your post reply !!!
thank you very much for you help.
