PIC16F876 output problem
jths21
View user's profile Send private message Yahoo Messenger MSN Messenger ICQ Number
PostPosted: Mon Jan 14, 2008 8:06 pm     Reply with quote
Hi, I am new here and I'm new to PIC programming. I'm currently on a project of controlling a servo motor using PIC16F876. In the programming of the IC, I need to use it to output 0-255 byte using 8 pins, which I used up RB0 to RB7 as for the rotation angles of the servo.
I am using C to program the chip. On the variable declaration part, do I have to use byte or integer as the definition? The program part which I wrote for it is something like this:
byte i;
i=getc();
portb=i;
However, it doesn't seem to be working. Crying or Very sad Crying or Very sad I've even tried up using integer as the variable declaration. May I have some advice and help here on this? Thanks a lot in advance.
JustinTeoh
jths21
PostPosted: Mon Jan 14, 2008 9:17 pm     Reply with quote
Look at the gethex() function in the CCS file input.c.
It's in this directory:
c:\program files\picc\drivers\input.c
It can receive two hex characters typed in from Hyperterminal
and convert them to an integer. Then you can output the integer
to a port.
jths21
PostPosted: Mon Jan 14, 2008 10:24 pm     Reply with quote
hm..i think i'll paste up the actual program that i'm running..hope can give as reference and get advice from you all..thanks a lot...
#include<16F876.H>
#use RS232(baud=115200,xmit=PIN_C6,rcv=PIN_C7)
#fuses hs, nowdt, nolvp, noprotect
#byte PORTC=7
#byte PORTB=8
#byte PORTA=5
char a;            // ID
char b;            // Function Selection
char mode;          // Mode Set
char drive;         // Driver Mode
char rot;         // Rotation Mode
char sys;         // System Mode
char chg;         // Encoder Changes
char cntplr;            // Counter Polarity Set
char rst;         // Counter Reset
unsigned n;         // Motor Rotation Output Angle
// Main program
  set_tris_c(0x80);
  set_tris_b(0x00);
  set_tris_a(0x00);
do
    a=0;
    b=0;
    a=getc();   // Get ID
    b=getc();   // Get the symbol for which function to run
    PORTB = 0;   // Set all pins low for no output
   while( a == '1' )
      if( b == 'A'){
         mode = getc(); // Get mode set
         while( mode == 'C' ){
            output_high(PIN_A0);
            output_low(PIN_A0);
         while( mode == 'T' ){
         while( mode == 'F' ){
            output_low(PIN_A0);
      else if( b == 'B'){
         drive = getc(); // Get driving mode HOM or SERVO
         while( drive == 'H'){
            output_high(PIN_A1);
         while( drive == 'S'){
            output_low(PIN_A1);
      else if( b == 'C'){
         rot = getc(); // Get rotation mode CW or CCW
         while( rot == 'R'){
            output_high(PIN_A2);
         while( rot == 'C'){
            output_low(PIN_A2);
      else if( b == 'D'){
         sys = getc(); // Get system set mode
         while( sys == 'T'){
            output_high(PIN_A3);
         while( sys == 'F'){
            output_low(PIN_A3);
      else if( b == 'E'){
         n = getc(); // Get motor positioning rotation angle
         portb=n;
      else if( b == 'F'){
         chg = getc(); // Get encoder change set
         while( chg == 'T'){
            output_high(PIN_C0);
         while( chg == 'F'){
            output_low(PIN_C0);
      else if( b == 'G'){
         cntplr = getc(); // Get counter polarity set
         while( cntplr == 'T'){
            output_high(PIN_C1);
         while( cntplr == 'F'){
            output_low(PIN_C1);
            output_low(PIN_C1);
      else if( b == 'H'){
         rst = getc(); // Get counter reset
         while ( rst == 'T'){
            output_high(PIN_C2);
         while( rst == 'F'){
            output_low(PIN_C2);
     while( a != '1') // All output to low if different ID
        {output_low(PIN_C0);
      output_low(PIN_C1);
      output_low(PIN_C2);
      output_low(PIN_B0);
      output_low(PIN_B1);
      output_low(PIN_B2);
      output_low(PIN_B3);
      output_low(PIN_B4);
      output_low(PIN_B5);
      output_low(PIN_B6);
      output_low(PIN_B7);
      output_low(PIN_A0);
      output_low(PIN_A1);
      output_low(PIN_A2);
      output_low(PIN_A3);
      break;}
  }while(1);
the above are the codes i'm using..i'm very new to programming pic..never touch that before till now...thanks... Crying or Very sad
jths21
SET
PostPosted: Tue Jan 15, 2008 1:20 pm     Reply with quote
You use this construct a lot:
while( rst == 'F'){
output_low(PIN_C2);
Why not use:
if( rst == 'F'){
   output_low(PIN_C2);
The 'while' implies that the loop will execute more than once, so the
'if' is clearer. (Left the braces in for the more general case)
Lots of other issues - for example, why do this
#byte PORTC=7
#byte PORTB=8
#byte PORTA=5
as the CCS compiler does that for you? So
would be
output_b(0);
You should use 'Code' button and edit your post, make it a bit easier to follow Smile
jths21
PostPosted: Tue Jan 15, 2008 7:08 pm     Reply with quote
thanks for your suggestion...thanks a lot...
i'm still on the beginner learning stage..so a lot to learn up...
thanks....but my main question is on this part:
else if( b == 'E'){
         portb=n;
i cant make it right there...
jths21
