Guide to BUS CAN ? Help for beginners
Bretagne
PostPosted: Sun Jan 13, 2008 9:38 am     Reply with quote
Hello
We are going to try a communication between two 18f448 via a CAN Bus to test the connection of PIC to the CAN network.
We use 2 easypic4 + MCP2551
We would like just to send a data (2 bytes) from one to the other.
The 2nd node should respond by sending back the data incremented by 1. This (1st) node then does the same and sends incremented data back to 2nd node, etc.
Someone has this kind of source codes in his pocket ?...
Or maybe something similar ??
Stephane
FRANCE
PostPosted: Sun Jan 13, 2008 10:09 am     Reply with quote
Here's a test program for two boards to talk to each other:
http://www.ccsinfo.com/forum/viewtopic.php?t=29627&start=7
How to calculate CAN bus bit-timing values by using a free
program which you can download at the link given in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=22138&start=8
General trouble-shooting of CAN bus problems:
http://www.ccsinfo.com/forum/viewtopic.php?t=27936
Examples of problems when learning the CAN bus:
http://www.ccsinfo.com/forum/viewtopic.php?t=26733
http://www.ccsinfo.com/forum/viewtopic.php?t=26442
