kender
Open-collector or open-drain output on a PIC |
Posted: Fri Jan 04, 2008 8:57 pm |
Colleagues,
This is, probably an easy question for those who know the answer. Is there a way to arrange an open-collector or open-drain output on a PIC18F4520 without adding a separate transistor? I think, according to the datasheet, the answer is “no”.
Thanks,
- Nick _________________ Read the label, before opening a can of worms. |
Posted: Fri Jan 04, 2008 10:43 pm |
Use these two functions to emulate an open-drain output:
output_low(pin #);
output_float(pin #); |
kender
Posted: Fri Jan 04, 2008 11:02 pm |
Actually, I want the pin to have high impedance, when the PIC is powered down. Currently, I see that the pin is tied to ground, when Vcc = 0. _________________ Read the label, before opening a can of worms. |
RLScott
Posted: Sat Jan 05, 2008 8:41 am |
kender wrote: | Actually, I want the pin to have high impedance, when the PIC is powered down. Currently, I see that the pin is tied to ground, when Vcc = 0. |
The reason is that the protection diodes on the pin conduct toward Vcc. And if Vcc = 0, then any voltage higher than .7 volts will be shorted out.
Robert Scott
Ypsilanti, Michigan |
coast
Joined: 03 Jan 2008 Posts: 6 Location: WALDERSLADE, KENT,UK
o/c output |
Posted: Sun Jan 06, 2008 8:11 am |
open drain output does not require an external [spam] if you can constrain levels within the 0 to +5V range of yr power supply rails (or whatever yr PSU range happens to be). The internal protection diodes will dump energy back into the power rail above this level. If you DO need an external [spam] then ZVN3306 or sim. is normally a good bet (no other surrounding components). You may however choose to put a 1 meg pull down from gate to ground to control initial conditions (to make sure the [spam] is off during reset time) |
coast
the wierdness of this site |
Posted: Sun Jan 06, 2008 8:13 am |
Please note that the SPAM words in my last reply were what the CCS site chose to replace the word transistor with!!
Programmers can be very strange people. |
Posted: Sun Jan 06, 2008 8:52 am |
It is worth remembering, that this is 'inherent' in the outputs of the PIC, without even considering any deliberate protection devices added. If you take a P channel FET, and ground the gate, and source, there will be an apparent diode seen if you try then to raise the drain.
SET
Posted: Wed Jan 09, 2008 2:02 pm |
We got caught out where we had a design that drove a triac optocoupler by current sinking into port pins. At power up there would sometimes be a glitch.. changing to source drive fixed it.
So the port pins definitely 'gulp' some current at power up - as to why:
1. Protection diodes - doubtful, as the pin and power pin will ramp up at the same time
2. P-channel FET - but if you raise the drain (i.e. the pin), the source would also rise (the supply) sot he inherent diode wont conduct?, and of course the gate shouldnt conduct...
There might be implications for battery powered systems, which are switched on and off - though I suppose the amount of 'gulp' current will be low. |
spam, eggs, bacon and spam... |
Posted: Thu Jan 10, 2008 10:11 am |
I noticed the above message and I wanted to test the spam out.
transistor, eggs, bacon and transistor.
So I typed; XSTR, eggs, bacon and XSTR. where XSTR is the full name - t r a n s i s t o r
Let's see if this works? |
Posted: Thu Jan 10, 2008 10:13 am |
Nope - didn't work... I wonder how the other chap spelled the word - transistor that the board edited it out with [Spam]??? |
newguy
Posted: Thu Jan 10, 2008 10:17 am |
I bet it's either 1) trans or 2) tran.
1) T r a n s
2) t r a n
edit: nope. |
SET
Posted: Thu Jan 10, 2008 10:44 am |
Try T r a n n y
[spam]
Yep :-) |
asmallri
Posted: Thu Jan 10, 2008 11:02 am |
An easy solution to this is to add a Schottky diode, Cathode connected to the PIC output pin. The anode becomes the "open drain" output. _________________ Regards, Andrew
Posted: Thu Jan 10, 2008 4:53 pm |
[spam], eggs, bacon and [spam]!
Yeah - Monty Python Lives!
