cidik Guest
| i have problem with lm35 and adc |
Posted: Wed Jan 09, 2008 6:18 pm |
i wrote this code but code is not working can anyone help me? tnx
| Code: | #include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#define use_portb_lcd TRUE
#include <lcd.c>
unsigned long int ham;
float voltaj,sicaklik;
setup_psp(PSP_DISABLED); // PSP birimi devre dışı
setup_spi(SPI_SS_DISABLED); // SPI birimi devre dışı
setup_timer_1(T1_DISABLED); // T1 zamanlayıcısı devre dışı
setup_timer_2(T2_DISABLED,0,1); // T2 zamanlayıcısı devre dışı
setup_CCP1(CCP_OFF); // CCP1 birimi devre dışı
setup_CCP2(CCP_OFF); // CCP2 birimi devre dışı
setup_adc(adc_clock_div_32); // ADC clock frekansı internal RC
setup_adc_ports(AN0); // Tüm AN girişleri analog
set_adc_channel(0);
delay_us(20);
printf(lcd_putc,"\fSicaklik=");
delay_ms(50);
output_b(0x00);
ham=read_adc();
delay_ms(200);
output_b(0x00);
voltaj=(0.0048828125*ham)*1000;
sicaklik=(voltaj/10)+2;
lcd_gotoxy(10,1);
printf(lcd_putc,"%5.1f'C",sicaklik);
delay_ms(200);
output_high(pin_b0);
deepakomanna
| Re: i have problem with lm35 and adc |
Posted: Thu Jan 10, 2008 2:43 am |
| cidik wrote: | i wrote this code but code is not working can anyone help me? tnx
#include <lcd.c>
set_adc_channel(0);
delay_us(20);
delay_ms(50);
output_b(0x00);
ham=read_adc();
delay_ms(200);
output_b(0x00);
lcd_gotoxy(10,1);
delay_ms(200);
try this,
SETUP_ADC_PORTS(sAN0|VSS_VDD );
& while reading ADC folow this ,
SET_ADC_CHANNEL(0);
DELAY_US(20);
TEMP_VALUE = READ_ADC();
SETUP_ADC(ADC_OFF);
hope i helped you  _________________ Thank You,
With Best Regards,
Deepak. |
SET
Posted: Thu Jan 10, 2008 10:58 am |
| Quote: | | Code: |
delay_ms(50);
output_b(0x00); <---
ham=read_adc();
delay_ms(200);
lcd_gotoxy(10,1);
printf(lcd_putc,"%5.1f'C",sicaklik); |
Why do you write 0 to Port B twice? It looks like you use Port B for the LCD module comms:
| Quote: | | Code: | | #define use_portb_lcd TRUE | |
Posted: Thu Jan 10, 2008 1:48 pm |
| SET wrote: | | Quote: | | Code: |
delay_ms(50);
ham=read_adc();
delay_ms(200);
lcd_gotoxy(10,1);
hi i used this because i wrote a code. this code was sending (1) to b0 when adc_int is activated. i was delete that. and i ll try to delete this lines from program. im newbie on pic and ccs c. tnx for the answer.
| Quote: |
try this,
SET_ADC_CHANNEL(0);
DELAY_US(20);
SETUP_ADC(ADC_OFF);
hope i helped you  |
u are helping me by the answering question. if it will not work i'll thank you anyway. i ll try this dude thanks
my english is poor sorry for this. take care |
