| printf question..... |
Posted: Thu Jan 03, 2008 5:26 pm |
Hi all,
I have a line of code that outputs two temperatures to an LCD as follows:
fprintf(LCD, "1: %lu F 2: %lu F", Temp[0], Temp[1]);
Before this code, I test Temp[0] and Temp[1] to be sure they are each in the appropriate range, and their respective sensor has not become disconnected. If a disconnect is detected, I'd like to replace the temperature value with '--' or 'NC' or something like that to flag the user. The problem is how to do this with printf that is setup for numeric data? The data type must be specified and it's a numeric value, not some ASCII text. I can do this with lots of kludgy code, but was wondering if there is a neat and clean way to accomplish it?
Thanks!
Dave |
Posted: Thu Jan 03, 2008 5:48 pm |
I don't think there exists a very elegant solution and you will always come to a variation of the code below: | Code: | if Sensor1Disconnected
fprintf(LCD, "1: NC ");
fprintf(LCD, "1: %lu F", Temp[0]);
if Sensor2Disconnected
fprintf(LCD, " 2: NC ");
fprintf(LCD, " 2: %lu F", Temp[1]); |
Posted: Tue Jan 08, 2008 10:52 am |
Hi All,
OK, a related question:
I want to insert the degree symbol into the data that is displayed on the LCD. Here is what I am sending to the serial LCD now:
I know that the degree symbol exists in the character set of the LCD display, and I can display it by itself using:
My question is how do I put everything in the same line? If I break the line up into multiple statements, I can't get it to compile
Thanks,
Dave |
Posted: Tue Jan 08, 2008 11:11 am |
#define DEGREE 0xDF
fprintf(LCD, "1: %lu %cF", Temp[0],DEGREE);
You can also include it directly, with:
fprintf(LCD, "1: %lu \xDFF", Temp[0);
Posted: Tue Jan 08, 2008 11:44 am |
Ttelmah,
Great! Works like a charm! Thanks for the tip!
Dave |
