Problem with i2c and the TRIS settings
Atraxz
PostPosted: Fri Jan 04, 2008 3:32 am     Reply with quote
Need help with a problem using i2c to communicate with either E2 or a RTC. The problem lies in getting the i2c to work properly.
Compiler ver. 4.064
using a PIC18F65j10
When this problem ocurred i created this small test program to rule out any side effects from the other code.
// Debugging I2C
#include "18F65J10.h"
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=8000000)
#use i2c(master,scl=PIN_C3,sda=PIN_C4,force_hw,fast=400000,stream=RTCE2)
void main(){   set_tris_b( 0xFC );
   set_tris_c( 0x98 );
   set_tris_d( 0x00 );
   set_tris_e( 0xFF );
   set_tris_f( 0x00 );
   set_tris_g( 0x1c );
   while(1){
      i2c_start(RTCE2);            // Pull bus low
      i2c_write(RTCE2, 0xA2);         // Send slave adress, write cmd
      i2c_write(RTCE2, 0x03);         // Adress where data will be written
      i2c_write(RTCE2, 0xAA);         // Test data
      i2c_stop(RTCE2);
But even this simple program presents me with the same problem which is: The previous code will result in a totally silent i2c. To get the i2c up and running i must first set tris_c pin c3 & c4 ( SCL & SDA) to outputs and thereafter setting the pins to inputs again. Following code will get the i2c to work as it should
// Debugging I2C
void main(){
   set_tris_b( 0xFC );
   set_tris_c( 0x80 );   // SDA & SCL outputs
   set_tris_c( 0x98 );   // SDA & SCL inputs
   set_tris_d( 0x00 );
   set_tris_e( 0xFF );
   set_tris_f( 0x00 );
   set_tris_g( 0x1c );
   while(1){
      i2c_stop(RTCE2);
By setting SDA & SCL to outputs then inputs will get the i2c to work. But once the i2c has started to work I can program it with the first code again and it will still work as long as the only warm reset ocurres. Unplugging the voltage to the PIC will force me to program the TRIS C as output and thereafter as inputs to get it to work again. According to MPLAB the trisc is set correctly with both programs but only the second works. The i2c communication problem is verified using oscilloscope. Any ideas? What am I missing?
rnielsen
PostPosted: Fri Jan 04, 2008 9:59 am     Reply with quote
Do you really need to be controlling the tris? It should only be used in conjunction with fast_io. I like to allow the compiler to control the I/O when I'm working with I2C. I haven't tried controlling the tris manually with I2C communications but I would imagine it would cause problems since it needs to be switched from input to output and back while communicating.
Ronald
PostPosted: Fri Jan 04, 2008 2:07 pm     Reply with quote
A very strange startup problem. What do you have connected to the I2C lines? Are all required pull-up resistors in place?
What is the silicon revision of your chip?
