ozanbuyuk Guest
| 16f88 interrupt rs232 |
Posted: Mon Dec 31, 2007 9:04 am |
Please help me...
My code dosen't work...
#include <16F88.h>
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOIESO //Internal External Switch Over mode
#use rs232(baud=9600,parity=N,xmit=PIN_B5,rcv=PIN_B2,bits=8)
#int_rda
void kesme()
disable_interrupts(int_rda);
printf("Kesme Calisiyor...");
output_high(Pin_B1);
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
enable_interrupts(GLOBAL); // Aktif edilen tüm kesmelere izin ver
while(1) // Sonsuz döngü
enable_interrupts(int_rda); // int_rda kesmesi aktif
Posted: Mon Dec 31, 2007 10:40 am |
In order to clear the interrupt flag you have to read the data from the UART or your code will never leave the interrupt routine. Add a call to getc() in your interrupt routine.
Also, after reception of more than 3 characters the UART will stall. Add the ERRORS keyword to your #rs232 line to automatically clear the overflow flags. |
