Chawee Guest
memcpy problem |
Posted: Mon Dec 31, 2007 2:00 am |
i have a problem with memcpy.
Here is my code:
BYTE CONST data1[30] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // 32
0x00, 0x00, 0x5F, 0x5F, 0x00, 0x00, // 33
0x00, 0x03, 0x00, 0x03, 0x00, 0x00, // 34
0x14, 0x3E, 0x14, 0x14, 0x3E, 0x14, // 35
0x4E, 0x4A, 0xFF, 0x4A, 0x7A, 0x00, // 36
BYTE CONST data2 [5][6] = {
void print_array()
int i = 0;
int font_data[50];
memcpy(font_data, data1[0], 6);
for(i=0;i<30;i++)
printf(" 0x%x",font_data[i]); // IF I USE A "ONE DIMENSION ARRAY"
delay_ms(100); // I GET GARBAGE
memcpy(font_data, data2[0], 6);
for(i=0;i<30;i++)
printf(" 0x%x",font_data[i]); // IF I USE A "TWO DIMENSION ARRAY"
delay_ms(100); // THE RESULT IS OK
Can anyone help me on my problem, because i want to use memcpy also
at "normal arrays"
Compiler Version 4.048
Happy New Year
Chawee |
Posted: Mon Dec 31, 2007 5:32 am |
You need to give it the starting address of the array:
Quote: | memcpy(font_data, data1, 6); |
Because CCS doesn't support pointers to constant data,
you can't do address arithmetic on the source address.
For example, the 2nd parameter can't be 'data+6' or &data[6]
or &data[i]. The compiler gives an error message if you do that.
But CCS makes an exception to their rule, by allowing memcpy to
work if you give it the starting address of the 'const' array, as
shown in the example above. |
