measuring and showing
engaddar
PostPosted: Wed Dec 26, 2007 9:31 am     Reply with quote
how can i show the data on 4 digit 7 segment display while measuring the ac voltage 50 hz.i use 16f877.if i measure the voltage it is 50 hz and it is 20ms so the display oscillations!!
SherpaDoug
PostPosted: Wed Dec 26, 2007 12:34 pm     Reply with quote
Do you have a zero crossing detector to synchronize your readings with the 50Hz line voltage? Check out Microchip application note AN521
http://ww1.microchip.com/downloads/en/AppNotes/00521c.pdf
engaddar
thaks but it is not the answer that i looked for!!!
PostPosted: Wed Dec 26, 2007 2:21 pm     Reply with quote
i measure the frequency for example 50 hz when i sent it to display an oscillation comes into being.so there is a problem between measure and showing on the display.what can i do???
SherpaDoug
PostPosted: Wed Dec 26, 2007 2:46 pm     Reply with quote
Can you describe the oscillation, maximum, minimum, frequency?
If it is only one count you may have a synchronization problem which will either require a sync pin like in AN521, or to live with it.
engaddar
i want to say that
PostPosted: Wed Dec 26, 2007 3:36 pm     Reply with quote
can you say me "can i measure the frequency and show it on 4 digit 7 segment display AT THE SAME TIME." i work to measure frequency 50 Hz it is 20 ms so when i want to see it on the display an oscillation(vibration) comes into being.thanks:))
SherpaDoug
PostPosted: Wed Dec 26, 2007 4:12 pm     Reply with quote
I take it the display FLICKERS because the PIC can't multiplex the segments of the display while it is reading the 50Hz.
The only ways I can think of to deal with that are hardware such as adding a second PIC or display driver chip, or clever software. The software would have to divide the tasks into tiny time slices and balance their allocation so everything gets done on time. There is no magic bullet. You need to study your system requirements and and your hardware and do the best you can.
Sorry I can't be of more help.
gjs_rsdi
flicking display
PostPosted: Wed Dec 26, 2007 5:02 pm     Reply with quote
16F877 can read and display at the same time. 16MHz gives 250ns=PC
even at 4MHz, 1us=PC will do it.
if I understand correct, you are reading the frequency and your problem is 7 seg flickering ?
the 7 seg. display need to have a latch/buffer/driver not to flicker. otherwise you are turning on/off the 7 seg. and it flickers.
I used 74HC4511 and common cathode leds.
if your 4 digits 7 seg. have integrated latch/buffer see tha data sheet how to to enable/disable the latch.
joseph
aykut
PostPosted: Thu Dec 27, 2007 3:04 am     Reply with quote
thank you very much.but i couldn't find a driver for 4 digit 7 segment.your example is only for one 7 segment display.:((((
engaddar
thanks
PostPosted: Thu Dec 27, 2007 3:06 am     Reply with quote
gjs_rsdi
7 seg driver
PostPosted: Thu Dec 27, 2007 3:08 am     Reply with quote
you have the 4*7 seg data sheet ? if yes, let me know how to find it, I will try to help
joseph
engaddar
here
PostPosted: Thu Dec 27, 2007 3:21 am     Reply with quote
http://www.brightled.com.tw/GetPdfFile.aspx?no=BQ-M404RI
engaddar
here
PostPosted: Thu Dec 27, 2007 3:36 am     Reply with quote
http://www.brightled.com.tw/GetPdfFile.aspx?no=BQ-M516RI
gjs_rsdi
4x7 segment flickering
PostPosted: Thu Dec 27, 2007 4:29 pm     Reply with quote
As you will read in the article, your display don't need driver. You have to update each 7 segment at least 100 time per second (10 ms interval). Doesn't mather don't have new data, you must to update the 7 seg.
http://www.melabs.com/resources/articles/ledart.htm
joseph
gjs_rsdi
4*7 seg flickering
PostPosted: Thu Dec 27, 2007 4:53 pm     Reply with quote
If you are worry about the current from the cathode pins, you can buffer them with npn transistors/transistor array/ with 10k on the base or buffer like ULN2003A
joseph
