i2c between PIC's 16F74
ArMo
PostPosted: Wed Dec 26, 2007 2:17 pm     Reply with quote
I'm have some problem with my communicaton i2c between PIC16F74's...
I try to write one simple code for write/read between pic's, but my code don't read nothing. Sad
Can someone show me where I have gone wrong? I'm a little confused.
//MASTER CODE:
#include <16F74.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#use delay(clock=16000000)
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3)
//=============== GLOBAIS ======================
char s[]= {"- write -"};
char buffer[0x20];
char data;
int i,j;
void led()
output_bit(PIN_A3,0);
output_bit(PIN_A3,1);
void buffer()
if(j<25)
buffer[j]=data;
j++;
else j=0;
port_b_pullups(TRUE);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
// TODO: USER CODE!!
//================= WRITE =====================
if(!input(PIN_A0)) // write in slave
i2c_start(); // Begin
i2c_write(0xa0); // Control Byte (write)
i2c_write(0x20); // Address
for (i=0;i<10;i++)
i2c_write(s[i]); // Data (10 char's)
i2c_stop(); // end
led(); // Led
//============= READ ===================
if(!input(PIN_A2)) // read in slave
i2c_start(); // begin
i2c_write(0xA0);
i2c_write(0x20);
i2c_start();
i2c_write(0xA1);
for(j=0;j<25;j++)
data = i2c_read();
buffer();
i2c_stop();
led();
// SLAVE CODE:
#include <16F74.h>
#device adc=8
#FUSES HS //Crystal osc (>4mhz)
#use i2c(Slave,Slow,sda=PIN_C4,scl=PIN_C3,address=0xA0)
//============= GLOBAIS ==================
BYTE buffer[0x20];
char c;
int8 data;
char r[]="- Ok -";
int i=0;
int j;
//=========( BUFFER )========================
void buffer()
if (i<25> state=0: Address match received with R/W bit clear
//=========( STATE<80 )======================
if(state<0x80>1)
data=rx;
c=data;
putc(c);
buffer();
//=====( STATE=80 )=======================
if(state==0x80) // Address match received with R/W bit set
i2c_start();
i2c_write(0x20);
for (j=0;j<10;j++)
i2c_write(r[j]);
i2c_stop();
//=====( STATE<FF )==================
if(state<0xFF) //Transmission completed and acknowledged
void main ()
enable_interrupts(INT_SSP);
while (1)
Thank you for your time.
ArMo
PostPosted: Wed Dec 26, 2007 2:24 pm     Reply with quote
if (i<25> state=0:
The code in your post is messed up, because of a setting in the forum.
To fix it, do this:
Click on the word "Profile", in the upper left corner of the CCS forum
page. Then edit your user profile and select the box to disable HTML.
Set it for "No":
Always allow HTML: No
Then edit your post, delete the code, and paste in new code.
This will fix the problem. Then the code will look OK.
ArMo
PostPosted: Wed Dec 26, 2007 2:39 pm     Reply with quote
I do it... that's all rigth now ???
PostPosted: Wed Dec 26, 2007 2:44 pm     Reply with quote
if(state<0x80>1)
It's still not fixed.
1. You need to edit your original post. Delete all the code.
2. Copy and paste in new code, from your editor (MPLAB or CCS).
3. Look below the posting window. Make sure that this box is selected:
x Disable HTML in this post
4. Then press the Submit button.
ArMo
PostPosted: Thu Dec 27, 2007 6:04 am     Reply with quote
I did it ... it´s ok ?? PLEASE HELP ME
PostPosted: Thu Dec 27, 2007 1:26 pm     Reply with quote
The code is not posted OK. Look at it. Many statements are messed up.
I suggest that you give up on posting the code. Instead, try the
following:
Use the CCS example file code, Ex_Slave.c, for the Slave PIC.
It's in this directory:
c:\Program Files\picc\Examples\Ex_Slave.c
Use the code in this post for the Master PIC:
http://www.ccsinfo.com/forum/viewtopic.php?t=32368&start=3
