code from avr to pic
Homie
PostPosted: Wed Dec 26, 2007 11:16 am     Reply with quote
Hi there im trying to change a driver for the Wiznet NM7010B+ netværks modul. its written for an avr chip, and im trying to get it to work on a pic. its hard because im not that good Smile now i got alot errors:
expecting an identifier
one of the errors is in this line:
void read_data(char s, volatile char * src, volatile char * dst, unsigned int len);
PostPosted: Wed Dec 26, 2007 11:57 am     Reply with quote
Delete the 'volatile' keyword in two places.
Also be aware that in CCS an 'int' is an unsigned 8-bit variable.
The other compiler may consider an 'int' to be a signed 16-bit variable.
If that is true, then in CCS you should change the declaration of
'unsigned int len' to 'int16' (or 'unsigned int16').
Homie
PostPosted: Wed Dec 26, 2007 12:06 pm     Reply with quote
ok great i can just delete the volatile? i didnt knew that int is 8bit in CCS :P
thanks alot mate
Homie
PostPosted: Wed Dec 26, 2007 2:04 pm     Reply with quote
is there anybode who can help me transform this code to pic??
* __DEF_MCU_xxx__ : define option related to MCU
#define __DEF_MCU_AVR__
#ifdef __DEF_MCU_AVR__
   #include <stdio.h>
   #include <string.h>
   #include <avr/interrupt.h>
   #include <avr/io.h>
   #ifdef __DEF_IINCHIP_INT__
      // iinchip use external interrupt 4
      #define IINCHIP_ISR_DISABLE()   (EIMSK &= ~(0x10))
      #define IINCHIP_ISR_ENABLE()   (EIMSK |= 0x10)
      #define IINCHIP_ISR_GET(X)      (X = EIMSK)
      #define IINCHIP_ISR_SET(X)      (EIMSK = X)
   #else
   #endif
#endif
PostPosted: Wed Dec 26, 2007 2:17 pm     Reply with quote
You don't need any of it in CCS. For example, see the small program
in this post, which shows how to do UART receiver interrupts with CCS:
http://www.ccsinfo.com/forum/viewtopic.php?t=30380&start=3
Homie
PostPosted: Wed Dec 26, 2007 2:29 pm     Reply with quote
Thanks mate. Now I got it to work compile without errors Smile
