Why AD7706 and AD7715 drivers use software SPI?
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue Dec 18, 2007 7:53 am     Reply with quote
Just curious: why AD7706 and AD7715 drivers, which come with the IDE (v3.240), use software SPI and not hardware SPI?
Cheers,
- Nick
Read the label, before opening a can of worms.
SherpaDoug
PostPosted: Tue Dec 18, 2007 9:02 am     Reply with quote
My guess is that a lot of PICs don't have SPI hardware. If you do it in software it is easier to adapt to any PIC.
treitmey
PostPosted: Tue Dec 18, 2007 9:11 am     Reply with quote
I'm not sure but
it might be that a common "developers kit" that has these
chips on it happens to use the software spi,... thus the drivers
are written around them. Do you know of any kit boards that
have the AD7706 or AD7715 on them??
kender
PostPosted: Tue Dec 18, 2007 9:54 am     Reply with quote
Today I have to get the readings from AD7718 into a PIC18LF4520, and AD7718 is an SPI part. I want to use SPI on the PIC. The registers of AD7718 look similar to those of AD7706, and I was hoping that I could reuse the driver.
My first try is to see what I get, when I read an empty SPI bus. I’ve physically removed all SPI peripherals. I have no pull-ups. For some reason spi_read() consistently returns 0x87. I was expecting 0x00, 0xFF or random noise. Does anyone know why I’m consistently getting 0x87?
Does anyone have sample code for AD7718 or AD7706, (they share the datasheet)?
P.S. I’m not a big fan of SPI – I prefer to use I2C whenever I can.
kender
PostPosted: Sat Dec 22, 2007 5:45 am     Reply with quote
Changing from spi_read() to spi_read(0) solved this problem.
kender
PostPosted: Sat Dec 22, 2007 8:15 am     Reply with quote
To make sure that my SPI bus works, I'm reading a hard-wired product code from the AD7718. It should be 0x4X (the second nobble depends on the silicon version). Here's my code (the helper functions only drive the chip-select low and high and call spi_write and spi_read):
      spi_write_AD7718(0b01001111);  // address the ID register for reading
      fprintf(DBUG, "0x%2X \n\r", spi_read_byte_AD7718());
I'm getting:
0x43
0x00
0x00
0x00
0x43
0x00
0x00
and so on
Every 4th reading is the correct code. The rest are zeros. Where do all the zeros come from?
PostPosted: Sat Dec 22, 2007 2:15 pm     Reply with quote
1. Post a short but complete test program.
2. Post your compiler version.
3. Post the list of connections between the PIC and the AD7718.
kender
PostPosted: Tue Dec 25, 2007 5:46 pm     Reply with quote
#include <18F4520.h>
#device ICD=TRUE
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock=5068800)
#use rs232(baud=115200, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8, stream=BT)
#use rs232(DEBUGGER, xmit=PIN_B5, stream=DBUG)
void
spi_write_AD7718(int8 iByte)
// PURPOSE: 1 byte to AD7718
   output_low(ADC_CS);
   spi_write(iByte);
   output_high(ADC_CS);
int8
   int8 iRet = 0;
   output_low(ADC_CS);
   iRet = spi_read(0);
   return iRet;
void init_hw()
   int8 iCh;
   setup_adc_ports(NO_ANALOGS | VSS_VDD);
   setup_adc(ADC_OFF | ADC_TAD_MUL_0);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_64);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_3(T3_DISABLED | T3_DIV_BY_1);
   setup_vref(VREF_LOW | -2);
   setup_low_volt_detect(FALSE);
   setup_oscillator(FALSE);
   init_hw();
   while (1)
      delay_ms(200);
PCWH v3.240
Here it is:
PIC         AD7718
SDO (43)    DIN (24)
SDI (42)    DOUT (23)
SCLK (37)   SCLK (20)
D7 (5)      CS# (21)
PostPosted: Tue Dec 25, 2007 6:27 pm     Reply with quote
I can't really look at your code until tomorrow but one quick question
is, are you using an LVP programmer ? 99% of all programmers are
High Voltage programmers (ICD2, ICD-U40, etc). If you're using a
normal programmer, then you need to change that fuse to NOLVP.
kender
PostPosted: Tue Dec 25, 2007 7:35 pm     Reply with quote
If you could look at my code tomorrow, I'd really appreciate it.
I have ICD-U40, and I'm using high-voltage programming. I'll change the fuse to NOLVP, although I don't have any apparent problems downloading into the PIC.
Have a great Christmas!
PostPosted: Wed Dec 26, 2007 2:03 pm     Reply with quote
The SPI mode is wrong. In the statement above, you have selected
SPI Mode 1. You can tell this by looking at the table below:
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
Look at page 11 in the AD7718 data sheet:
http://www.analog.com/UploadedFiles/Data_Sheets/AD7708_7718.pdf
It has two timing diagrams the show the relationship between SCLK and
data. You can determine the SPI mode from these diagrams. There
are only four possible modes. The important things to notice are:
1. The SCLK signal is at a high level when it's inactive.
2. The rising edge of SCLK occurs in the middle of each data cell.
Look at the timing diagrams down at the bottom of this page:
http://elm-chan.org/docs/spi_e.html
It shows the four SPI modes. The diagram that matches page 11
of the AD7718 data sheet is the one for SPI Mode 3.
You need to modify your setup_spi() statement to use the constant
for Mode 3. Paste the four #define statements into your program,
so they are above main(). Then delete SPI_L_TO_H from setup_spi()
and put in SPI_MODE_3 instead.
Some other things --
This is a bug in the CCS Wizard. There is no legal "-2" parameter.
Just delete that line.
This baud rate won't work with your crystal frequency. Go to this web
page and download the PicBaud program.
http://www.micromagicsystems.com/picbaud/4523812801
(This website plays a sound when you go to it).
Put in 5.0688 for the frequency, and 115200 for the baud rate. With
BRGH = 1, you get 8.33% error from the ideal baud rate. That's not
good enough. You won't be able to communicate with a PC. It needs
to be less than 2%, and the lower the better.
