RAM corruption (I don't think it's my fault!)
markie
PostPosted: Mon Dec 24, 2007 3:09 pm     Reply with quote
Hi all,
I am using v4.057 and a PIC18F2520. At first all seemed well and everything worked fine, but as my project grew (a digitally controlled preamp, so growth was inevitable) seemingly random faults kept popping up. I would add some code, and other code would stop working or produce gibberish on the LCD, etc etc.
I have spend three days now trying to figure it out, and it seems that it is *not* my coding that's been at fault. I only use a couple of simple arrays so far, and have a primitive Fault() functions which stores a value in eeprom then calls a reset_cpu(). I use this to check for various array overflow conditions or other things which aren't supposed to happen. This function isn't getting called (though I have verified it works), so I have concluded that the problem isn't anything to do with my code overwriting the RAM and corrupting things.
Today I found out about the .lst and .sym stuff. As it happens I could get my program to near enough work, with just one piece of array data corrupted and everything else functioning fine, and to completely fail - simply by moving a single loop variable (k) declaration a few lines up in the program. Working = declare at beginning of main function, broken = declare just before the for loop!
I compared the .lst and .sym for the "working" code and the broken code. When declared at the top of the main function, I saw the variable in the .sym file. When declared just before the loop, the variable completely disappeared from the .sym file. I assume the compiler decided to locate it in some kind of temporary memory. This would actually explain the exact behaviour I was seeing!
The loop in question was the main loop for my primitive task system. It looked at each task and ran the appropriate function if it was scheduled. The broken compile was never exiting the for loop around the task array, and was only ever executing task 0, even though other tasks were being scheduled. I figure the loop variable being in some kind of temporary space made the variable keep being reset to 0 after calling the task execution function.
Here's the part of code that was failing. Where the "int k" is currently, it "works". If I move it to just before the for(), it dies.
void MainLoop()
   unsigned int k = 0;
   while (TRUE)
      // Only do task stuff if the power is actually on
      if (GetPowerState())
         // Run each scheduled task
         for (k = 0; k < MAX_TASKS; k++)
            if (Scheduled(k))
               ExecuteTask(k);
      } else {
         sleep();
         if (Scheduled(TASK_POWER_ON))
            ExecuteTask(TASK_POWER_ON);
Anyway, further looking at the 'working' compile I saw that the corruption on some of the text I was seeing was because the compiler has decided to reuse that RAM space, which that array sits in, for some functions I call later on, so the text was being overwritten. The array in question is a compile time defined array just holding some simple preamp source selection names (Computer, Tuner, TV /AV etc etc), so of course the text remains corrupted and eventually gets displayed on the LCD.
char sourceNames[7][21] = {   "Computer", "CD / DVD", "AUX", "Tuner", "Tape", "TV / AV", "MP3 Player"   };
"Tape" is the one that's currently corrupted, though it has been other things in the past like "Tuner" and "CD / DVD".
From the .lst, here is the above array being assigned at main()
1D28 0E43           07364 MOVLW  43
1D2A 6F92           07365 MOVWF  x92
1D2C 0E6F           07366 MOVLW  6F
1D2E 6F93           07367 MOVWF  x93
1D30 0E6D           07368 MOVLW  6D
1D32 6F94           07369 MOVWF  x94
1D34 0E70           07370 MOVLW  70
1D36 6F95           07371 MOVWF  x95
1D38 0E75           07372 MOVLW  75
1D3A 6F96           07373 MOVWF  x96
1D3C 0E74           07374 MOVLW  74
1D3E 6F97           07375 MOVWF  x97
1D40 0E65           07376 MOVLW  65
1D42 6F98           07377 MOVWF  x98
1D44 0E72           07378 MOVLW  72
1D46 6F99           07379 MOVWF  x99
1D48 6B9A           07380 CLRF   x9A
1D4A 6B9B           07381 CLRF   x9B
1D4C 6B9C           07382 CLRF   x9C
1D4E 6B9D           07383 CLRF   x9D
1D50 6B9E           07384 CLRF   x9E
1D52 6B9F           07385 CLRF   x9F
1D54 6BA0           07386 CLRF   xA0
1D56 6BA1           07387 CLRF   xA1
1D58 6BA2           07388 CLRF   xA2
1D5A 6BA3           07389 CLRF   xA3
1D5C 6BA4           07390 CLRF   xA4
1D5E 6BA5           07391 CLRF   xA5
1D60 6BA6           07392 CLRF   xA6
1D62 0E43           07393 MOVLW  43
1D64 6FA7           07394 MOVWF  xA7
1D66 0E44           07395 MOVLW  44
1D68 6FA8           07396 MOVWF  xA8
1D6A 0E20           07397 MOVLW  20
1D6C 6FA9           07398 MOVWF  xA9
1D6E 0E2F           07399 MOVLW  2F
1D70 6FAA           07400 MOVWF  xAA
1D72 0E20           07401 MOVLW  20
1D74 6FAB           07402 MOVWF  xAB
1D76 0E44           07403 MOVLW  44
1D78 6FAC           07404 MOVWF  xAC
1D7A 0E56           07405 MOVLW  56
1D7C 6FAD           07406 MOVWF  xAD
1D7E 0E44           07407 MOVLW  44
1D80 6FAE           07408 MOVWF  xAE
1D82 6BAF           07409 CLRF   xAF
1D84 6BB0           07410 CLRF   xB0
1D86 6BB1           07411 CLRF   xB1
1D88 6BB2           07412 CLRF   xB2
1D8A 6BB3           07413 CLRF   xB3
1D8C 6BB4           07414 CLRF   xB4
1D8E 6BB5           07415 CLRF   xB5
1D90 6BB6           07416 CLRF   xB6
1D92 6BB7           07417 CLRF   xB7
1D94 6BB8           07418 CLRF   xB8
1D96 6BB9           07419 CLRF   xB9
1D98 6BBA           07420 CLRF   xBA
1D9A 6BBB           07421 CLRF   xBB
1D9C 0E41           07422 MOVLW  41
1D9E 6FBC           07423 MOVWF  xBC
1DA0 0E55           07424 MOVLW  55
1DA2 6FBD           07425 MOVWF  xBD
1DA4 0E58           07426 MOVLW  58
1DA6 6FBE           07427 MOVWF  xBE
1DA8 6BBF           07428 CLRF   xBF
1DAA 6BC0           07429 CLRF   xC0
1DAC 6BC1           07430 CLRF   xC1
1DAE 6BC2           07431 CLRF   xC2
1DB0 6BC3           07432 CLRF   xC3
1DB2 6BC4           07433 CLRF   xC4
1DB4 6BC5           07434 CLRF   xC5
1DB6 6BC6           07435 CLRF   xC6
1DB8 6BC7           07436 CLRF   xC7
1DBA 6BC8           07437 CLRF   xC8
1DBC 6BC9           07438 CLRF   xC9
1DBE 6BCA           07439 CLRF   xCA
1DC0 6BCB           07440 CLRF   xCB
1DC2 6BCC           07441 CLRF   xCC
1DC4 6BCD           07442 CLRF   xCD
1DC6 6BCE           07443 CLRF   xCE
1DC8 6BCF           07444 CLRF   xCF
1DCA 6BD0           07445 CLRF   xD0
1DCC 0E54           07446 MOVLW  54
1DCE 6FD1           07447 MOVWF  xD1
1DD0 0E75           07448 MOVLW  75
1DD2 6FD2           07449 MOVWF  xD2
1DD4 0E6E           07450 MOVLW  6E
1DD6 6FD3           07451 MOVWF  xD3
1DD8 0E65           07452 MOVLW  65
1DDA 6FD4           07453 MOVWF  xD4
1DDC 0E72           07454 MOVLW  72
1DDE 6FD5           07455 MOVWF  xD5
1DE0 6BD6           07456 CLRF   xD6
1DE2 6BD7           07457 CLRF   xD7
1DE4 6BD8           07458 CLRF   xD8
1DE6 6BD9           07459 CLRF   xD9
1DE8 6BDA           07460 CLRF   xDA
1DEA 6BDB           07461 CLRF   xDB
1DEC 6BDC           07462 CLRF   xDC
1DEE 6BDD           07463 CLRF   xDD
1DF0 6BDE           07464 CLRF   xDE
1DF2 6BDF           07465 CLRF   xDF
1DF4 6BE0           07466 CLRF   xE0
1DF6 6BE1           07467 CLRF   xE1
1DF8 6BE2           07468 CLRF   xE2
1DFA 6BE3           07469 CLRF   xE3
1DFC 6BE4           07470 CLRF   xE4
1DFE 6BE5           07471 CLRF   xE5
1E00 0E54           07472 MOVLW  54
1E02 6FE6           07473 MOVWF  xE6
1E04 0E61           07474 MOVLW  61
1E06 6FE7           07475 MOVWF  xE7
1E08 0E70           07476 MOVLW  70
1E0A 6FE8           07477 MOVWF  xE8
1E0C 0E65           07478 MOVLW  65
1E0E 6FE9           07479 MOVWF  xE9
1E10 6BEA           07480 CLRF   xEA
1E12 6BEB           07481 CLRF   xEB
1E14 6BEC           07482 CLRF   xEC
1E16 6BED           07483 CLRF   xED
1E18 6BEE           07484 CLRF   xEE
1E1A 6BEF           07485 CLRF   xEF
1E1C 6BF0           07486 CLRF   xF0
1E1E 6BF1           07487 CLRF   xF1
1E20 6BF2           07488 CLRF   xF2
1E22 6BF3           07489 CLRF   xF3
1E24 6BF4           07490 CLRF   xF4
1E26 6BF5           07491 CLRF   xF5
1E28 6BF6           07492 CLRF   xF6
1E2A 6BF7           07493 CLRF   xF7
1E2C 6BF8           07494 CLRF   xF8
1E2E 6BF9           07495 CLRF   xF9
1E30 6BFA           07496 CLRF   xFA
1E32 0E54           07497 MOVLW  54
1E34 6FFB           07498 MOVWF  xFB
1E36 0E56           07499 MOVLW  56
1E38 6FFC           07500 MOVWF  xFC
1E3A 0E20           07501 MOVLW  20
1E3C 6FFD           07502 MOVWF  xFD
1E3E 0E2F           07503 MOVLW  2F
1E40 6FFE           07504 MOVWF  xFE
1E42 0E20           07505 MOVLW  20
1E44 6FFF           07506 MOVWF  xFF
1E46 0E41           07507 MOVLW  41
1E48 0101           07508 MOVLB  1
1E4A 6F00           07509 MOVWF  x00
1E4C 0E56           07510 MOVLW  56
1E4E 6F01           07511 MOVWF  x01
1E50 6B02           07512 CLRF   x02
1E52 6B03           07513 CLRF   x03
1E54 6B04           07514 CLRF   x04
1E56 6B05           07515 CLRF   x05
1E58 6B06           07516 CLRF   x06
1E5A 6B07           07517 CLRF   x07
1E5C 6B08           07518 CLRF   x08
1E5E 6B09           07519 CLRF   x09
1E60 6B0A           07520 CLRF   x0A
1E62 6B0B           07521 CLRF   x0B
1E64 6B0C           07522 CLRF   x0C
1E66 6B0D           07523 CLRF   x0D
1E68 6B0E           07524 CLRF   x0E
1E6A 6B0F           07525 CLRF   x0F
1E6C 0E4D           07526 MOVLW  4D
1E6E 6F10           07527 MOVWF  x10
1E70 0E50           07528 MOVLW  50
1E72 6F11           07529 MOVWF  x11
1E74 0E33           07530 MOVLW  33
1E76 6F12           07531 MOVWF  x12
1E78 0E20           07532 MOVLW  20
1E7A 6F13           07533 MOVWF  x13
1E7C 0E50           07534 MOVLW  50
1E7E 6F14           07535 MOVWF  x14
1E80 0E6C           07536 MOVLW  6C
1E82 6F15           07537 MOVWF  x15
1E84 0E61           07538 MOVLW  61
1E86 6F16           07539 MOVWF  x16
1E88 0E79           07540 MOVLW  79
1E8A 6F17           07541 MOVWF  x17
1E8C 0E65           07542 MOVLW  65
1E8E 6F18           07543 MOVWF  x18
1E90 0E72           07544 MOVLW  72
1E92 6F19           07545 MOVWF  x19
If I then search for xE7, which is apparently the second character in the "Tape" string, I get various results of this location being reused.
                    04795 ....................
                    04796 .................... //
                    04797 .................... // Clear the display
                    04798 .................... //
                    04799 .................... void lcd_ClearDisplay()
                    04800 .................... {
                    04801 ....................    lcd_SendCommand(0x01);
1728 0E01           04802 MOVLW  01
172A 6FE7           04803 MOVWF  xE7
172C EC9D F004      04804 CALL   093A
1730 6A18           04805 CLRF   18
1732 BEF2           04806 BTFSC  FF2.7
1734 8E18           04807 BSF    18.7
1736 9EF2           04808 BCF    FF2.7
                    04809 ....................    delay_ms(2);
                    04771 .................... //
                    04772 .................... // Turn the display on / off
                    04773 .................... //
                    04774 .................... void lcd_display(short enable)
                    04775 .................... {
                    04776 ....................    if (enable)
1746 53DF           04777 MOVF   xDF,F
1748 E005           04778 BZ    1754
                    04779 ....................    {
                    04780 ....................       lcd_SendCommand(0x0C);
174A 0E0C           04781 MOVLW  0C
174C 6FE7           04782 MOVWF  xE7
174E EC9D F004      04783 CALL   093A
                    04784 ....................    } else {
1752 D004           04785 BRA    175C
                    04786 ....................       lcd_SendCommand(0x08);
1754 0E08           04787 MOVLW  08
1756 6FE7           04788 MOVWF  xE7
1758 EC9D F004      04789 CALL   093A
                    04790 ....................    }
                    04791 ....................
                    04792 ....................    //delay_ms(1);
                    04793 .................... }
175C 0C00           04794 RETLW  00
and some others...
So, I guess my question is... is there any simple way to tell the compiler to stop doing this sort of thing!? I have tried turning the optimization setting in the global compile options right down, but this has no effect. I have also tried making all variables static, or just the global variables static, both of which also doesn't seem to solve the issue.
I am using multiple source files. Though it compiles fine, perhaps this is a problem....?
Unless requested I won't post the code yet as there's a fair bit of it, but here's my fuses and basic config stuff
#include <18F2520.h>
#device PIC18F2520   *=16   ADC=10   ICD=FALSE   HIGH_INTS=FALSE
// Configuration
//////// Fuses: LP,XT,HS,RC,EC,EC_IO,H4,RC_IO,PROTECT,NOPROTECT
//////// Fuses: BROWNOUT_NOSL,BROWNOUT_SW,NOBROWNOUT,BROWNOUT,WDT1,WDT2,WDT4
//////// Fuses: WDT8,WDT16,WDT32,WDT64,WDT128,WDT,NOWDT,BORV20,BORV27,BORV42
//////// Fuses: BORV45,PUT,NOPUT,CPD,NOCPD,NOSTVREN,STVREN,NODEBUG,DEBUG
//////// Fuses: NOLVP,LVP,WRT,NOWRT,WRTD,NOWRTD,IESO,NOIESO,FCMEN,NOFCMEN
//////// Fuses: PBADEN,NOPBADEN,CCP2B3,CCP2C1,WRTC,NOWRTC,WRTB,NOWRTB,EBTR
//////// Fuses: NOEBTR,EBTRB,NOEBTRB,CPB,NOCPB,LPT1OSC,NOLPT1OSC,MCLR,NOMCLR
//////// Fuses: XINST,NOXINST,INTRC,INTRC_IO,WDT256,WDT512,WDT1024,WDT2048
//////// Fuses: WDT4096,WDT8192,WDT16384,WDT32768
#fuses INTRC_IO
#fuses NOWDT
#fuses NOPROTECT
#fuses NOLVP
#fuses NOPUT
#fuses BROWNOUT
#fuses BORV42
#fuses NODEBUG
#fuses NOXINST
#fuses MCLR
#fuses STVREN
#fuses IESO
#fuses FCMEN
#fuses NOPBADEN
#use delay(clock=32M)
Sorry for the lengthy post!
markie
PostPosted: Mon Dec 24, 2007 4:02 pm     Reply with quote
Aha!
With some more searching (I have been searching these forums for a few hours too), I came across this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=32221&highlight=linker
I read the three links posted and rearranged my source files to do it the 'traditional' CCS way, rather than using the linker. It seems to keep it modular-ish, and I flashed this compile...... no more corruption on the text! I guess it must be the linker to blame.
I guess it has to recompile the lot each time, rather than just changed modules and relinking....... but at least it seems to be working now. I'm over the moon! Smile
Thanks PCM! Should the problem reappear using this method I will post back, but I have a feeling it won't Smile
