Basic I2C for 12F675 problems
apl01
PostPosted: Wed Dec 19, 2007 1:31 am     Reply with quote
i am trying to use I2C between master and slave. I have read a lot of posts and experimented but cant get comms working. I am trying to get the master to send 0x20 to the slave and then for the slave to receive it and turn on Pin_A2 but nothing happens?
Master
#include <12F675.h>
#device adc=8
#FUSES NOWDT, INTRC_IO, NOCPD, NOPROTECT, NOMCLR, NOPUT, NOBROWNOUT
#use i2c(master,fast,SDA=PIN_A0,SCL=PIN_A1)
while(1){
i2c_start();
i2c_write(0xA0);
i2c_write(0x20);
i2c_stop();
Slave
#include <12F675.h>
#device adc=8
#FUSES RC //Resistor/Capacitor Osc with CLKOUT
#use i2c(SLAVE, SDA=PIN_A0, SCL=PIN_A1, address=0xA0, FORCE_HW)
BYTE incoming;
while(1){
incoming = i2c_read();
if(incoming=0x20)
output_high(PIN_A2);
}[/quote]
PostPosted: Wed Dec 19, 2007 1:53 am     Reply with quote
The 12F675 does not have an SSP module. The #use i2c() statement
only works with a hardware i2c module. The CCS manual says:
The SLAVE mode should only be used with the built-in SSP.
You need to get a PIC that has an SSP or MSSP module.
apl01
PostPosted: Wed Dec 19, 2007 2:38 am     Reply with quote
Ok, can i use rs232 instead of I2C? I have developed some rs232 code similar to that of the I2C code above which doesn't work should i post a new topic?
PostPosted: Wed Dec 19, 2007 12:47 pm     Reply with quote
If it doesn't work, then post it.
