forward declaration
surfman19
forward declaration
PostPosted: Thu Dec 13, 2007 11:24 am     Reply with quote
I want to ask whether this c compiler support a forward declaration of a struct?
struct foo;
struct test
    struct foo a;
struct foo
    int i;
Neutone
PostPosted: Thu Dec 13, 2007 3:55 pm     Reply with quote
Download the demo and try it out.
I would expect any compiler that requires explicit variables to throw an error.
PostPosted: Fri Dec 14, 2007 2:40 pm     Reply with quote
its not working..but why?
cu
PostPosted: Fri Dec 14, 2007 3:07 pm     Reply with quote
Your code doesn't compile in MSVC++ 2005. It gives this error:
error C2079: 'test::a' uses undefined struct 'foo'
PostPosted: Fri Dec 14, 2007 4:51 pm     Reply with quote
struct foo;
struct test
    struct foo *a;
struct foo
    int i;
this code is working with MSVC++ 2005 but not with ccs! why?
PostPosted: Fri Dec 14, 2007 5:10 pm     Reply with quote
Don't know. Email CCS support and ask them.
kender
PostPosted: Sun Jul 06, 2008 11:54 pm     Reply with quote
Colleagues,
I want to have a structure that has a pointer to another structure of the same type.
typedef struct
   structS*         pParent;       // HSM parent state
structS;
Does the CCS compiler v4.071 support forward declaration? Is it still work in progress?
I've tried every example of the struct forward declaration I could find on the web (not shown in the code above), but none of them seemed to compile. I guess, I can have a void* pointer cast to structS* as a fallback approach.
I'll e-mail CCS support about this too.
Cheers,
- Nick
Read the label, before opening a can of worms.
PostPosted: Mon Jul 07, 2008 4:34 am     Reply with quote
It is only latter languages like C++, that support forward declaration.
If you set VC, to compile using C syntax, it will error on this declaration.
It is actually very difficult to do, without dynamic memory management.
Just declare a pointer to a generic type, and reference this in the structure, then cast this to refer to the required type in use.
Ken Johnson
PostPosted: Mon Jul 07, 2008 10:00 am     Reply with quote
I think this is straight out of the old K&R reference (well, the struct def, anyway):
#include "18F4520.h"
typedef struct sTag {
    struct sTag *pS;
} structS;
void    main (void)
    structS s;
    s.pS = 0;
    for ( ;; ) ;
This comiles ok using V4.075
Good luck,
Ken
PostPosted: Mon Jul 07, 2008 10:11 am     Reply with quote
Yes. That is not a forward reference, since you define the structure name before using it. Perfectly legitimate.
What C++ introduces is having an undeclared structure type referred to in a declaration.
What you post, should do what the original poster wants.
kender
PostPosted: Mon Jul 07, 2008 11:40 pm     Reply with quote
Ken, thanks for the code! It worked for me. I've e-mail CCS support, and Darren had e-mailed me back his code, which was almost identical to yours.
I'm toying with an idea of OOP with ANSI C on the PIC. Here's a paper, which explains how to approach that www.cs.rit.edu/~ats/books/ooc.pdf.
I've tried to make my "class" one step more convoluted (notice the "self" pointer in the typedef for the function pointer):
typedef void (*fptypeSomeMethod)(
   structS*   pSelf,  // alas, structS is not yet declared at this point
   int8     iSomeArg);
typedef struct _structS
   fptypeSomeMethod  fpMyMethod;
   struct _structS* pSuper;        // superclass
   int8     m_iMyMemberVar;
structS;
But I think (goig back to Ttelmah's message) that can't be done without a pSelf being void*.
PostPosted: Tue Jul 08, 2008 2:16 am     Reply with quote
Exactly.
It was this ability, that C++, added to the older syntax. You can have a void pointer, which automatically 'types itself', when used. However you can get the same basic 'effect', by just using a pointer to an existing type (like byte), and casting it when you use it. Just means you need to add the cast. Beware also, that you need to be very careful about the bracketing of the cast, if you perform pointer arithmetic.
