I use spi_setup in main.c and #use i2c in at24.c. They share the same pin RC3,RC4. The chip i use is pic18f452.
In main.c i use read/write spi normaly without using i2c,but when i call i2c function it doesn't work and spi doesn't work too.
Can anyone help me to solve this problem?
Thanks very much!
rnielsen
Posted: Fri Dec 14, 2007 9:52 am
You cannot use them at the same time. They use the same hardware. I've read, on this forum, that you can switch between them but I've never done it and I can't remember how. Search this forum and you should find your answer.
