arrow
PIC powered through PIN_B6 |
Posted: Thu Dec 13, 2007 3:34 am |
Hi
I am using the PIC18F2550.
When the board is plugged into a receptacle the power pin receives power and PIN_B6 is checked if it is H or L. This is how things should work.
What happens in reality, sometimes, is that PIN_B6 sees the H first (before the chip is powered), and this seems to power the PIC.
I have tried to trim the receptacle's PIN_B6 pin shorter so that mechanically it gets a H after the power pin. This helps, but does not work 100%.
Can someone please tell me if there is a way to switch off the PIC from being powered through PIN_B6?
Are there any other possilbe things I can try?
Thank you in advance
a. |
Posted: Thu Dec 13, 2007 3:53 am |
You need a reasonably high resistance in the line connected to B6.
All pins on MOS logic devices like the PIC, normally have an internal 'protection' diode, to prevent the pin being pulled above the supply rail, and destroying the chip. If you are directly connecting a line capable of supplying the pin, to such a pin, it _will_ supply the chip through this diode.
What you do, is feed your signal through something like a 100KR series resistor. Then when the chip is 'off', only 50uA can flow through this, and the chip doesn't get powered. When the chip is on, this is still a good enough connection, to signal the operation required.
arrow
Posted: Thu Dec 13, 2007 4:06 am |
Hi Ttelmah
As always a good suggestion- Thank you!
May I ask: What is the minimum (approximately) current that is needed for the PIC to be powered through the pins (eg PIN_B6)?
Also what is the minimum V on an input pin (with respect to V supply) for the PIC to see a H?
Once again thank you
a. |
Posted: Thu Dec 13, 2007 6:06 am |
The minimum, will depend to some extent on the configuration (oscillator frequency, and loads). The clamp diodes are rated for 20mA. A typical pic at 4MHz, will draw something like 4mA to run. The chips draw a minimum of about 100uA, in their lowest power 'running' mode (low frequency oscillator etc.), hence my choice of 50uA to keep well clear of this. The voltage needed to see for a 'high', will depend on the input buffer for the pin concerned. For a TTL input, normally 2v. For a Schmitt input, 4v (both assuming the chip is on a 5v supply). Port B, normally has TTL inputs. The input leakage, is normally under 1uA, so any resistance of under 3MR, connected to 5v, will be enough to be 'seen' as a high. However something lower, provides more margin. CCS, use 220K, for their detection of 5v, on the USB bus, which gives a typical example of this.
arrow
Posted: Thu Dec 13, 2007 8:09 am |
Hi Ttelmah
Thank you!! I have just tested it with 51kR in series with the input Vdd and it works well now.
(I have another R=100k to ground and PIN_B6 connects where 51k and 100k meet).
I appreciate your help.
a. |
Posted: Thu Dec 13, 2007 10:17 am |
Good. That sounds safe.:-)
