This is not absolute my code, but example my problem.
This code not work very good. If data change, code not run new "case".
I use fast_io. Data input B3-B0-pin.
data=input_b()&0x0f;
while(data != 0) //
switch (data)
case 0b1101:
data_new=data;
x_minus();
case 0b1011:
data_new=data;
x_plus();
case 0b0111: // Eteen, ei kaasua
case 0b1111:
But if i add delay, code work but slow.
delay_ms(1000); // I add this.
switch (data)
Posted: Thu Dec 13, 2007 8:53 am
What is connected to your data input pins B0-B3? Are these (keyboard) switches?
If yes, then that's your problem. Switches can bounce (open and close) for as long as 20ms before reaching a stable new state, that's why you need debouncing hardware or software routines. More good info can be found in the thread http://www.ccsinfo.com/forum/viewtopic.php?t=32166.
In case you have a keyboard matrix connected a debounce function is provided in the file KBD.C in the driver directory of your CCS compiler.
