pklein
| Problem with PWM Duty Cycle |
Posted: Wed Dec 12, 2007 3:17 pm |
I cannot get a 10 bit pwm duty cycle. When I put a number that is higher than 8 bit into the duty cycle I get full pwm duty.
This is my code:
setup_ccp2(CCP_PWM);
setup_timer_2(T2_DIV_BY_1, 63, 1);
set_pwm2_duty((int16)255);
I can only vary pwm in the 8 bit range. Is there something else I need to change. Im using a 16F917
Thanks |
Posted: Wed Dec 12, 2007 4:02 pm |
I compiled the following test program with vs. 4.064 and it worked in
10-bit pwm mode. Your test value for duty cycle is very close to 100%,
so all you will see on the oscilloscope is a very thin negative pulse.
I put in the following duty cycle values, and measured the pulse width
on an oscilloscope. Since I'm using a 20 MHz crystal, the clock period
is 50 ns, and the pulse width does change in 50 ns increments, which
is correct for 10-bit PWM operation.
Duty cycle Negative pulse
value width
255 50 ns
254 100 ns
253 150 ns
252 200 ns |
#include <16F877.H>
#use delay(clock = 20000000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
Posted: Wed Dec 12, 2007 4:25 pm |
The key is the setup timer statement.
The PWM range, is a maximum of 10bits, also limited to 4* the timer maximum count+1. With a timer setup of 63, the PWM limit, is 4*64. To get a full 10bit PWM, the timer setup has to increase to 255. With the example given, and 63 in the timer, you will get 255:256 on, with just a single 50nSec low pulse.
pklein
Posted: Wed Dec 12, 2007 11:37 pm |
| Thanks. That makes perfect sense. I didnt know about it being limited to 4 times the timer count. |
Posted: Thu Dec 13, 2007 3:47 am |
On most PICs, there is to be a table in the data sheets, giving the 'effective' PWM resolution, with different timing setups. This seems to have disappeared from a few of the latest PIC sheets, but if you pull one of the older ones (for example, the one for the 16F684), then table 11-4, gives "example pwm frequencies and resolution", with the output frequency, and the 'effective resolution' in bits on the bottom line.
