spom
| Problem with interrupt |
Posted: Wed Dec 12, 2007 5:05 am |
I have a little problem with interrupts.
I use a stepping motor which should rotate right and after 168 steps rotate left. This works fine.
But now the motor should pause for 7 minutes and then starts again.
My Problem is, that the timer starts counting after the motor's rotation which takes approximately 15 seconds.
How can I handl this?
Thanks!
My code below:
#include <16f818.h>
#use delay(clock=8000000)
#fuses NOWDT,HS,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP
int8 switchstate;
int16 seconds;
int8 int_count;
#define INTS_PER_SECOND 61
#int_rtcc
void clock_isr() {
if(--int_count==0) {
++seconds;
int_count=INTS_PER_SECOND;
#BYTE port_b = 6
#define FOUR_PHASE TRUE
#ifdef FOUR_PHASE
BYTE const POSITIONS[4] = {0b0101,
0b1001,
0b1010,
0b0110};
#else
BYTE const POSITIONS[8] = {0b0101,
0b0001,
0b1001,
0b1000,
0b1010,
0b0010,
0b0110,
0b0100};
drive_stepper(BYTE speed, char dir, BYTE steps)
static BYTE stepper_state = 0;
BYTE i;
for(i=0; i<steps; ++i) {
delay_ms(speed);
set_tris_b(0xf0);
port_b = POSITIONS[ stepper_state ];
if(dir!='R')
stepper_state=(stepper_state+1)&(sizeof(POSITIONS)-1);
stepper_state=(stepper_state-1)&(sizeof(POSITIONS)-1);
main()
BYTE speed, steps;
char dir;
set_timer0(0);
setup_counters( RTCC_INTERNAL, RTCC_DIV_128 | RTCC_8_BIT);
enable_interrupts(INT_RTCC);
if(seconds == 420)
if(switchstate==0)
switchstate=1;
speed = 40;
steps = 168;
dir='F';
drive_stepper(speed,dir,steps);
speed = 40;
steps = 168;
dir='R';
switchstate=0;
seconds = 0;
Posted: Wed Dec 12, 2007 7:08 am |
| Quote: | My Problem is, that the timer starts counting after the motor's rotation which takes approximately 15 seconds.
How can I handl this? | The answer is already present in your question. Do not reset the seconds timer after you have activated the motor but do it before, i.e. direct after the 7 minutes test.
Note that your current code waits 7 minutes. Activates the motor. Waits again 7 minutes before repeating the sequence. There is a total pause of 14 minutes between the motor activations, is that as intended? |
rnielsen
Posted: Wed Dec 12, 2007 9:32 am |
One way is to place an if() statement in your ISR that will enable/disable your counting routine. You could have this variable set by your drive_stepper() routine when it reaches it's destination. It could be cleared by the ISR when your counter reaches 0.
One thing to note here, it is not a good idea to have key words as part of your variable names. int_count is an example. Bad things can happen when the mind sees this and is coasting in neutral.
Ronald |
