String concatenation at compile time
Laurent Chouinard
PostPosted: Tue Dec 11, 2007 8:08 am     Reply with quote
I would like to know if there is a way to do string concatenation at compile time, like:
In PHP i would do  "blah" . "something"
In VB I would do: "blah" & "something"
and it appears as one string to the code.
Anything available for the CCS compiler? (v3)
JoaoSantos
PostPosted: Tue Dec 11, 2007 8:39 am     Reply with quote
Hello, You can use the standard C function strcat(str1, str2) in "string.h"
Laurent Chouinard
PostPosted: Tue Dec 11, 2007 8:45 am     Reply with quote
I mean concatenation at compile time, not at runtime.
Ken Johnson
PostPosted: Tue Dec 11, 2007 8:58 am     Reply with quote
I believe you simply write the strings as:
"string1" "string2" "etc"
and the compiler will make one string of all.
Ken
Laurent Chouinard
PostPosted: Tue Dec 11, 2007 9:04 am     Reply with quote
Yes! Thank you, it works.
I assumed the compiler required a character to do it, like most other...
PostPosted: Mon Dec 17, 2007 2:18 pm     Reply with quote
I think this is standard behavior for compilers. The following is from
the help file for MSVC++:
When specifying string literals, adjacent strings are concatenated. Therefore, this declaration:
char szStr[] = "12" "34";
is identical to this declaration:
char szStr[] = "1234";
