ex_usb_mouse.c sample circuit
madcyantist314
PostPosted: Sat Dec 08, 2007 2:49 pm     Reply with quote
I am entirely new to this topic and am trying to get this code to run. I have been able to compile it and get the code onto the chip but I cannot find a sample circuit to go with the code. Is there anyone that could provide me with a circuit that will run this example?
Thank you.
PS: I'm using the PIC18F4550
meereck
PostPosted: Sun Dec 09, 2007 3:53 pm     Reply with quote
A basic usb circuit looks like this:
http://pic18fusb.online.fr/wiki/wikka.php?wakka=WikiHome
madcyantist314
PostPosted: Sun Dec 09, 2007 4:15 pm     Reply with quote
But will that work for the sample code ex_usb_mouse.c? I don't belive it will.
meereck
PostPosted: Mon Dec 10, 2007 6:46 am     Reply with quote
sure it will,
ex_usb_mouse.c doesn't use any leds nor switches. It just connects to a PC via the USB and draws a circle with the mouse cursor.
good luck
Futterama
PostPosted: Wed Jan 09, 2008 5:03 am     Reply with quote
meereck wrote:
sure it will,
good luck
Are you sure the example will run with a 20MHz crystal?
linera
PostPosted: Tue Apr 02, 2013 4:56 am     Reply with quote
Meereck, please.
Could you tell me where can I obtain the driver for this mouse example?
You can see a more detailed explanation about this question in the following topic:
http://www.ccsinfo.com/forum/viewtopic.php?p=174014#174014
Thanks in advance
PostPosted: Tue Apr 02, 2013 5:34 am     Reply with quote
to : linera
your link goes to a Proteus question !!
Please read PIC101 !!
As for the 'driver' you ask about....everything needed for the CCS C compiler usb_mouse program is supplied by CCS in their examples folder
However it sounds like you need a Proteus driver , so contact ISIS, or Proteus for their simulation of a driver.
CCS code works for real hardware in the real world.
Please do NOT ask for Proteus help here, no one has the time to rewrite faulty simulator code, life is way to short.
hth
jay
