theteaman
How slow can division really be? |
Posted: Sat Dec 08, 2007 7:43 am |
Hi
I've got timer0 set up as setup_timer_0(RTCC_DIV_16 | RTCC_8_BIT);
In my interrupt hander for this timer, I have practically nothing, just a few conditional flag setting statements.
When i compile my code I get the good ol' "interrupts have been disabled to prevent re-entrance @DIV3232" warning. But the problem is my interrupt handler is not calling any functions. The offending line is actually a division in another part of the program that is not called, in any way, by the clock interrupt - it's in the main loop.
When I change the division to an addition the warning disappears.
Does anyone know why this is happening?
ps. i am dividing int32s. |
Posted: Sat Dec 08, 2007 8:15 am |
Post the contents of your interrupt handler.
You won't get this message, unless you _are_ calling a division. The 'odds' are that something you don't think uses division, does.
theteaman
Posted: Sat Dec 08, 2007 3:51 pm |
Here it is:
#INT_TIMER0
//this function is called every time timer0 overflows, approx 1220 times per second
void clock_isr()
if(int_count % MOD_CLK_RES == 0)
mod = TRUE;
mod = FALSE;
int_count++;
I just discovered that changing the modulus to an addition stops the error.. any ideas? The handler hasn't changed for ages and it was working without warning for a few days but now suddenly it is causing this warning...
Thanks |
theteaman
Posted: Sat Dec 08, 2007 4:30 pm |
Thanks PCM, I will give it a try. |
Posted: Sun Dec 09, 2007 4:10 am |
It is also worth working out if you can perform this some other way.
The 'modulus' function, is a division. Modulus is the remainder from a division operation, and hence involves a division. Since the compiler refers to div32, it implies at least one of the numbers is a 32bit value, which implies you are talking about something in excess of 500 machine instructions, for this one operation... :(
Now if (for instance), 'MOD_CLK_RES', could be selected to be a binary value (8, 16 etc.), then you can get the same result, using:
if(int_count & (MOD_CLK_RES-1) == 0)
Which takes less than a dozen instructions.
Also, if this is a counter, and you want to know when it is divisible by (say) 60, to give a zero result, it is about 50 times quicker, to just run a second counter. So:
#INT_TIMER0
void clock_isr() {
static int16 modctr=0;
if (--modctr==0) {
modctr=MOD_CLK_RES;
mod=true;
else mod=FALSE;
int_count++;
Should give the same result (I am assuming 'MOD_CLK_RES', is < 65535), and will do it vastly quicker.
I'd avoid _anything_ involving division in an ISR. At 1220* per second, you could be borderline on actually executing the original code in the interrupt time (depending on the processor involved).
