HS in fuses
mcad
HS in fuses
PostPosted: Fri Dec 07, 2007 4:35 pm     Reply with quote
What does "HS" means in fuses directive ?
Thanks a lot
PostPosted: Fri Dec 07, 2007 4:44 pm     Reply with quote
This type of question was asked one week ago:
http://www.ccsinfo.com/forum/viewtopic.php?t=32876
PostPosted: Fri Dec 07, 2007 4:46 pm     Reply with quote
It means use the slightly higher gain 'high speed' oscillator. Should normally be selected for any crystal above 4MHz.
The chip's data sheet, does give the oscillator configurations, and though sometimes working out the CCS nomenclature can be slightly less than 'obvious', for this one (and XT etc.), the CCS name is identical to the one in the data sheet.
mcad
PostPosted: Fri Dec 07, 2007 4:47 pm     Reply with quote
Thanks a lot both of you.
Regards
