I2C Between Two 18F4431
Carl Eldredge
PostPosted: Fri Dec 07, 2007 12:07 pm     Reply with quote
I'm a neophyte in programming. Could someone please look at this code and tell me if they see anything wrong. I can't get it to work properly. A few times I was able to write to the slave, but it would never respond.
Thanks a lot.
Code for the Master:
#include <18F4431>
#fuses HS,NOPROTECT,BROWNOUT,NOWDT,BORV42
#use delay(clock=10M)
#use i2c(Master, sda=PIN_C4, scl=PIN_C5, SLOW=100000)
int ack;
//BYTE SSPADD = 24; // 100khz
void receive(int number)
if(!ack==0) // Acked?
printf(" # %x ERROR!!\n\r",number); // If not: ERROR
void read_write(void) // Write data and the read it.
BYTE data;
printf("Starting to write...\n\r");
i2c_start();
ack = i2c_write(0xa0); // Control byte (write)
receive(1);
ack = i2c_write(0x00); // Address
receive(2);
ack = i2c_write(0x42); // Write Data
receive(3);
i2c_stop(); // End
printf("If there were no errors, the write was successful.\n\r");
printf("Short delay...\n\r");
delay_ms(1000); // Allow 94 ms extra for safety
///////////////////////////READING//////////////////////////////////////////////
printf("Read is beginning...\n\r");
i2c_start();
ack=i2c_write(0xa0);
receive(1);
ack=i2c_write(0x00);
receive(2);
i2c_start();
ack=i2c_write(0xa1);
receive(3);
data = i2c_read(0);
i2c_stop();
printf("Read complete\n\r");
printf("Data: /%c/ \n\r",data);
while(true) // Loop forever
read_write();
printf("Wait for 10 seconds\n\r");
delay_ms(10000);
Code for Slave:
#include <18F4431.h>
#fuses XT, NOWDT, NOPROTECT, BROWNOUT, BORV42, PUT, NOLVP
#use delay(clock=4M)
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C5, address=0xa0, SLOW=100000, FORCE_HW)
BYTE address, buffer[0x10];
//BYTE SSPADD = 0x09; // Set baud rate to 100khz
#INT_SSP
void ssp_interupt()
BYTE incoming, state;
output_high(PIN_B2); // Turn on LED 3
state = i2c_isr_state();
if(state <0x80> 0x80)
output_high(PIN_B3); // Turn on LED 4
enable_interrupts(INT_SSP);
set_tris_c(0b11111111);
while(1) // Forever
if(buffer[address]==0x42) // If I2C worked
output_high(PIN_B1); // Flash LED 2
output_low(PIN_B1);
output_low(PIN_B0); // Turn off LED 1
output_high(PIN_B0); // Turn on LED 1
PostPosted: Fri Dec 07, 2007 2:03 pm     Reply with quote
1. The slave should be running at 8 MHz minimum.
2. You access the i2c receive buffer in main(), but you don't set
the index variable to a specific value.
while(1) // Forever
Also, edit your original post and fix the slave routine code.
Carl Eldredge
PostPosted: Fri Dec 07, 2007 4:27 pm     Reply with quote
Thanks. I actually got it working by lowering the baud rate. To speed it up, I'll get another crystal.
