PIC16F887 Startup Problem
rlgreen
PostPosted: Fri Dec 07, 2007 12:21 pm     Reply with quote
Hello All,
I have a problem getting my pic to run. The board works, because it works in assembly. I am sure it's my config setup. I'm using ver 4.023 and here is the simple code:
#use delay (clock=8000000)
#fuses INTRC,NOMCLR,IESO,PUT,NOPROTECT,NOWDT,BROWNOUT,NOLVP,BORV21,FCMEN,NODEBUG
#use rs232(baud=19200, xmit=PIN_C6,rcv=PIN_C7)
void main (void)
   set_tris_C(0x00);           //allouts
   setup_oscillator(OSC_8MHZ);
   // main loop
      PORTC = 0XFF;
      delay_ms(10);
      PORTC = 0X00;
      delay_ms(10);
I put a scope on portc and nothing. I'm sure it's me. What am I missing?
ECACE
PostPosted: Fri Dec 07, 2007 12:46 pm     Reply with quote
For starters, you have not defined the processor.
You first line should be something like:
#include <16F877A.h>
Try that and see if it works. Of course though if you did not have that in your code, I doubt it would compile without it. Did you list your whole program?
A HW Engineer 'trying' to do SW !!! Run!!!
rlgreen
PostPosted: Fri Dec 07, 2007 1:10 pm     Reply with quote
I did not list the whole file. i did have the include file. It seems that when I commented out the //#use(baud.....) the thing started working, so I guess it reserves that pinC6 for the uart. I'll get the hang of this C compiler yet Smile
Thanks for the fast reply!
