dac6573 support?
breeyet
dac6573 support?
PostPosted: Fri Dec 07, 2007 11:16 am     Reply with quote
I'm trying to interface a dac6573 to a PIC18F4585. Has anyone got example code for this?
PostPosted: Fri Dec 07, 2007 2:51 pm     Reply with quote
I don't have this chip to test, but the following driver and test program
is based on the DAC6573 data sheet. It should be enough to get you
started.
Remember to put pull-up resistors on the SDA and SCL lines.
#include <18F4585.h>
#fuses XT,NOWDT,BROWNOUT,PUT,NOLVP
#use i2c(Master, sda=PIN_C4, SCL=PIN_C4)
// The DAC6573 address pins A0,A1,A2,A3 must all
// be connected to ground.
#define DAC6573_I2C_WRT_ADDR  0x98
#define DAC6573_I2C_READ_ADDR 0x99
#define DAC6573_UPDATE_CMD    0x10
// Function parameters --
// Channel: 0 to 3.
// Data: 0 to 1023.
void DAC6573_write(int8 channel, int16 data)
 int8 command;
 // Format the channel select bits into the command byte.
 command = ((channel & 3) << 1) | DAC6573_UPDATE_CMD;
 i2c_start();
 i2c_write(DAC6573_I2C_WRT_ADDR);
 i2c_write(command);
 i2c_write(data >> 8);   // Write MSB
 i2c_write(data);        // Write LSB
 i2c_stop();
// Set channel 0 to the mid-range output voltage.
DAC6573_write(0, 512);
breeyet
PostPosted: Fri Dec 07, 2007 5:07 pm     Reply with quote
Wow, that was quick. Thanks for the help, I'll try it out as soon as I can and post the results.
