STIX
LM35 temp sensor reading (10°C off) |
Posted: Thu Jun 28, 2007 12:37 pm |
Hi:
I connected a LM35 temperature sensor to my PIC16F877A MCU to take temperature readings. The following is my code:
#include <16F877A.h>
#device *=16
#device ADC=10
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#fuses HS,NOWDT,NOPUT,NOPROTECT,NODEBUG,BROWNOUT,NOLVP,NOCPD,NOWRT
#USE DELAY(clock = 4000000)
#use RS232(baud = 9600, xmit = PIN_C6, rcv = PIN_C7)
void main ()
int16 value, value1;
setup_adc (ADC_CLOCK_DIV_8);
setup_adc_ports (AN0);
set_adc_channel (0);
while (1)
delay_ms (500);
value = read_adc ();
value1 = 5 * value * 100/1024;
printf ("Temp:%5.1fC\n\r", (float)value1);
The LM35 is connected directly to AN0 on the MCU. However, the readings I get are always 10°C off. For example, the thermometer in the room will read 24°C, but the number I see on the hyperterminal is 14°C. If I increase the room temperature to like 25°C, the LM35 will read 15°C. Anyone know why this is happening? Thanks in advance. |
SherpaDoug
Posted: Thu Jun 28, 2007 1:07 pm |
Put a voltmeter on the LM35 to see if it is a LM35 problem or a PIC problem. Also try putting the sensor in a glass of ice water to give a larger range of test data. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Steve H Guest
Posted: Thu Jun 28, 2007 1:58 pm |
LM35's also like to oscillate - many times this oscillation looks like a reading that is way off and/or not particularly stable. Check the output with a scope or put the voltmeter that Sherpa suggested on AC millivolts - there should be no AC noise on the output of the LM35.
The data sheet shows how to prevent oscillation by the addition of a large C and a resistor.
HTH - Steve H. |
caduhitec
Posted: Thu Jun 28, 2007 7:08 pm |
use this
delay_ms (500);
value1 = (value*49+1)/100;
STIX
Posted: Mon Jul 02, 2007 12:55 pm |
1). The reading I get on the voltmeter is more consistent with the thermometer (e.g. thermometer: 22°C, voltmeter reading: 20°C). However, the hyperterminal is still showing numbers that are way off, something like 14°C.
2). I put the voltmeter on AC millivolts and I didn't see any reading so I assume there's not much oscillation.
3). I also put a large resistor (470k) and a large capacitor (10u) across the output and ground. It didn't make any difference on the hyperterminal reading.
Is there something wrong with my code? I also tried the code suggested by caduhitec, but it didn't make any difference. I don't think I have a bad PIC because I just got it. Can anyone make other suggestions? Thanks. |
jma_1
Posted: Mon Jul 02, 2007 5:13 pm |
Greetings,
Try explicitly casting your result as an int32. Your multiplication of a 10 bit adc by 5 and 100 -> 1023 * 5 * 100 = 511500. The maximum value of an int16 is 65536. Alternatively, declare value1 as an int32.
When debugging code, examine the basics. Print out the adc value of your channel only (without the formula applied to convert v to c). Is the value correct? Apply a known voltage. Does the voltage match the adc reading? This well help determine if your channel is setup correctly (correct reference voltage, channel, etc).
Do you need to try and convert the integer into a float for displaying it on the lcd? You will never have a fraction portion of the number (integers only).
Please post your results.
Cheers |
BrunoCF
Posted: Mon Sep 10, 2007 8:27 am |
I had a the same issue. Guess what was the problem: the power suply of my PIC was 4V instead of 5V... :P All my calculations were made for 5V, so they were all wrong. |
E_KARVELAs
Joined: 14 Feb 2007 Posts: 46 Location: Greece & Cyprus
LM35 ANSWER TO THE ISSUE |
Posted: Tue Dec 04, 2007 8:50 pm |
HI
I was looking for same issue with u with lm35 and pic16f877a , i have find the answer.
take a look of my code for me have been worked wery well.
I think if u try the command i have pointed u with arrow it will work !!! Code: |
#include <16F877A.h> <---------------------------
#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT,NOLVP
#device ADC=10 <---------------------------
#use delay(clock = 4000000)
#byte PORTA=0X05
#byte PORTB=0X06
float oC=0;
float TempVal=0;
int counter=122;
PORTB=0X00;
PORTC=0X00;
set_tris_a(0xff);
set_RTCC(6);
setup_counters(RTCC_INTERNAL,RTCC_DIV_32);
enable_interrupts (INT_RTCC);
enable_interrupts (GLOBAL);
while(true)
// -----ADC SETUP------------
setup_adc_ports(AN0); // A0 Ref=Vdd
setup_adc(ADC_CLOCK_INTERNAL); // Internal 2-6us
set_adc_channel(0); // use AN0
oC = read_ADC();
TempVal = 5 * oC * 100/1024;
if(counter_thermo==30){
........=TempVal //<------- u can put here register of ur choice or what ever u want
counter_thermo=0;
} // end while true
} //end void main ()
#int_RTCC // Timer0 interrupt
void interrupt()
if(--counter>0)return;
counter=122;
++counter_thermo; // counter for start the show of thermometer
Now with ur code....try this!!!
//#device *=16 <----- u don't need this ,i don't so
#device ADC=10
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
void main ()
float value, value1; //<------ changed to float from int16
setup_adc (ADC_CLOCK_INTERNAL); // <--- i have changed here!!!
while (1)
delay_ms (500);
printf("Temp: %2.1fC" ,value1); // <----here!!!
try this and mail me if it work!!! _________________ ---- GREECE ---- |
Posted: Wed Dec 05, 2007 4:13 am |
I'm sorry, but it is rare to see so many bad bits in one section of code....
First, *=16, is needed, if he is intending to write a larger main program, using more memory locations latter.
Second, using 'ADC_CLOCK_INTERNAL, is a bad decision. It will make the results _worse_, since it introduces extra randomness into the noise. Read the chip's data sheet. Note what it says under table 11-1, with regards to using the internal RC clock. If this made your code work, are you sure that you were using the right divider dfrom the processor clock...
Third, all you are doing, with your RTC code, is adding a long pause between the readings. If this fixed your problem, it suggests that you were not allowing long enough between the readings (the capacitor inside the ADC in the PIC, takes _time_ to charge, and is only charging when you are not reading). The existing code being tried, has a good delay present.
Now, the original poster, says he has put a large resistor and capacitor on the output. This is _not_ what is needed. The manufacturers recommended damping, when significant capacitance is present, is 75R, _in series_ with 1uF to the ground rail. Try this first. The PIC's ADC input, presents a lot of capacitance when it connects and switches during the conversion. Unless your voltmeter is able to see signals lasting for only a few uSec, it wont detect these spikes, and this could easily give the odd behaviour.
I the reading is then still consistently off, you really sould look doubly carefully at the supply rail. Again, it might look 'good' on a DVM, but if noise spikes are present on this, this would give spurious results. What damping is on this rail, how close to the PIC?.
E_KARVELAs
Posted: Tue Jan 01, 2008 2:38 pm |
Ttelmah wrote: | I'm sorry, but it is rare to see so many bad bits in one section of code....
hi
For me my code works just fine...
Had had no problem...
Everything works just perfect...
Happy new year _________________ ---- GREECE ---- |
metalm
Joined: 22 Mar 2007 Posts: 23 Location: Buenos Aires, Argentina
Posted: Wed Jan 02, 2008 5:20 am |
The LM35 don't output few volts for connecting it directly to the AN pin of the pic? Don't need an operational amplifier?? |
E_KARVELAs
Posted: Wed Jan 02, 2008 10:34 am |
metalm wrote: | The LM35 don't output few volts for connecting it directly to the AN pin of the pic? Don't need an operational amplifier?? |
Hi
No u don't need an amp ic cuz the sensor LM35 has a linear output 10mV/C.
See datasheets for more info.
soulraven
Joined: 08 Feb 2009 Posts: 72 Location: campulung muscel
Posted: Mon Mar 02, 2009 8:08 am |
but for negative temperature?how to use LM35? |
Posted: Mon Mar 02, 2009 8:57 am |
You have to add a -ve voltage source, and an external op-amp as a level shifter. Look at figure 2 in the data sheet, and then a simple op-amp 'adder'. Use this to add sufficient offset voltage so that the lowest reading you want to use is going to be above 0v.
Probably cheaper and simpler, to consider a different IC. The LM135, gives the same 10mV/degree, but with this starting at 0v=-273.15C. You get 2.73v, at 0C, and the IC itself happily works down to -40C (lower in some versions).
Posted: Mon Mar 02, 2009 11:21 am |
i'ved used the LM-34 with the F886/887 - and rely on using an external 2.5 v V prec. ref -- to read temps mostly in the area of 150F to 212F.
looking at the schemo i drew - back when- - all i do is run the sensor on the same modestly regulated 5V as the PIC - but with a 4.7 uf tant cap on the 5V supply line to the sensor - the sensor cable is a flexible single pair audio cable - where the shield is the NEG return and the +5 and ret signal are the "pair" inside.
typical displacement is about 3 to 4 ft from the controller board.
i just tried one with 30 feet of cable and it still works FINE.
the receiver components going TO the pic are nothing more than a series 100 ohm resistor - shunted to ground by .1uF at the PIC pin input pin.
i get excellent matching at the 212F cal point ( +/- 1.5 deg F ) between LM34's and have never observed anything you could call instability. |
