SerialGmr8
| concatinating two int8's into an int16 |
Posted: Mon Dec 03, 2007 3:31 pm |
Hello C gurus,
im trying to merge two int8 values into an int16 as follows;
#include <16F877.h>
int8 storetemp[6]{0,1,2,3,4,5,6}
int8 i,s=0;
int8 tempmsb, templsb;
int16 templong;
main
for(s=0; s<6; s++)
templong = storetemp[s++];
tempmsb = templong;
send(tempmsb);
strobe_SND();
templong = templong<<8;
templong = templong & 0xFF00;
templong = templong | storetemp[i];
templsb = templong;
send(templsb);
strobe_SND();
however, the values i obtain from templsb & tempmsb are garbage. I've serached a few of the threads, but havent been able to apply anything ive seen in there to help me. As im calling out to you. Kindly advise.
best regards, |
frequentguest Guest
Posted: Mon Dec 03, 2007 3:42 pm |
| I didn't look at what you had done, but CCS has a built-in function to create an int16 from two int8. Look up make16() in the manual or help file. |
SerialGmr8
Posted: Mon Dec 03, 2007 6:17 pm |
surely worth a shot.
thanks frequentguest...
*you might as well sign up :P* |
Posted: Wed Dec 05, 2007 5:26 am |
As a comment on what may be wrong, what is setting 'i'...
