Reading Port B
ntype
Reading Port B
PostPosted: Mon Dec 03, 2007 8:13 am     Reply with quote
I'm using an 18f2520 PIC and would like to read the whole of port B. Ive tried to read using the following code within main()
portb = get_tris_b();
The read does not work. Is there additional port setup required? I will post my source when i get home if required.
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Mon Dec 03, 2007 9:41 am     Reply with quote
with the get_tris_b(); function you will get the setting of the TRIS register of port B, not port B itself.
You can try the input_b(); function for this purpose.
Hope this helps
PostPosted: Mon Dec 03, 2007 1:23 pm     Reply with quote
Hope this helps
ah i see. input_b() works fine. thanks foppi, u rock!
