Joined: 03 Dec 2005 Posts: 182 Location: Australia SA
error on stdlib.h on 24F part
Posted: Sat Dec 01, 2007 1:13 pm
FYI
I was trying to do a QSORT using the 24FJ64GA004 part where I always crash at typedef signed int8 (*_Cmpfun)(char * p1,char * p2);
I then added to the stdlib.h the following to compensate.
#if !defined(__PCD__)
#else
typedef signed int16 (*_Cmpfun)(char * p1,char * p2);
#endif
now compiles OK, I would suspect other part on this header file may need simular changes? _________________ What has been learnt if you make the same mistake?
Ken Johnson
Joined: 23 Mar 2006 Posts: 197 Location: Lewisburg, WV
Posted: Sun Dec 02, 2007 3:34 pm
Please send this to support@ccs.com so they can update the file(s)
Ken
Storic
Posted: Mon Dec 03, 2007 5:41 am
Has been sent to tech suport _________________ What has been learnt if you make the same mistake?
