what is the most simple function for Z and C flag decisions
asmboy
PostPosted: Sun Dec 02, 2007 11:02 am     Reply with quote
re 16F/C family :
when doing a series of bit shifts << , >> etc of varying lengths -
and then seeing results of a specific single BIT shifted out of the variable register - reading the C or Z flag in assembler was direct and EZ
yet i find there are no compiler defined functions to just read the
flags after an operation on the order of
a zflag() or Cflag() function.
Or are there ?
so far i've been using the ( obvious) defined bit read functions of register 03 to make decisions- but is there a better way or a defined function i simply don't see? is there a reason there is no compiler defined function for these two obvious, and important flags?
am i just being excessively thick here ?
what IS the most code efficient way to do it ?
asmboy
sorry forgot the example
PostPosted: Sun Dec 02, 2007 11:55 am     Reply with quote
i'm just trying to find out if there is a predefined or lower instrux count function than this:
.................... int1 Zflag() {
.................... return ( bit_test ( *StatusReg ,2));
0053: MOVLW 00
0054: BTFSC 03.2
0055: MOVLW 01
0056: MOVWF 78
PostPosted: Sun Dec 02, 2007 3:05 pm     Reply with quote
The compiler manual shows this method:
#bit CY = GETENV("bit:C")
#bit Z  = GETENV("bit:Z")
Then use CY and Z in your code as if they were variables.
i checked the .LST
PostPosted: Mon Dec 03, 2007 8:20 am     Reply with quote
WOW - i tried it and checked the resulting LST file -
Now thats as efficient as it gets!
THANKS and my apology
- i should have looked that up in the index of the compiler manual -
( if only there WAS an index ) it would have saved a lot of head scratching.
i have some old code to go clean up now with the improvement
