davevu22 Guest
Stepper motor controller |
Posted: Fri Nov 30, 2007 12:36 am |
I have a 6 wire stepper motor and I connect both center tap to 12V. My motor is a 1.8 degree so one rev would be 200 steps but i'm not getting that. My motor turns 1 rev per 50 steps and I'm not sure why. Here is my code.
Code: | #include <16F777>
#DEVICE ADC=8
#fuses INTRC_IO, NOWDT, NOPROTECT, NOBROWNOUT, NOMCLR
#use delay(clock = 8000000)
setup_oscillator(OSC_8MHZ);
main()
//int sequence[8] = {7,6,14,12,13,9,11,3}; //good
//int sequence[8] = {8,10,2,6,4,5,1,9}; // my own
int sequence[8] = {10,6,5,9};
//int sequence[4]={5,9,10,6};
//int sequence[8] = {10,8,9,1,5,4,6,2};
int i=0;
int16 c=0;
delay_us(2000);
output_B(sequence[i]);
i++;
if (i>3)
c++;
i=0;
if (c==500)
c=0;
davevu22 Guest
Posted: Fri Nov 30, 2007 12:38 am |
For the code above, i'm telling the motor to turn 10 times and stop for one second. The C=500 should be C=200 if it takes the motor 200 steps per rev.
Wierd. |
davevu22 Guest
Posted: Fri Nov 30, 2007 12:39 am |
davevu22 wrote: | For the code above, i'm telling the motor to turn 10 times and stop for one second. The C=500 should be C=200 if it takes the motor 200 steps per rev.
Wierd. |
Sorry I mean C=2000 |
Posted: Fri Nov 30, 2007 3:29 am |
When does C increment?.
Think about it, you are incrementing C, every four times round the loop (when i>3). Not suprising that the motor goes four times further than you expect.....
davevu22 Guest
Posted: Fri Nov 30, 2007 11:12 am |
To complete one step, don't you need to go output value 10,6,5,9 to port B? Its a full step sequence.
From what i've read, to make the motor turn 1.8 degree (1 step) I would have to output this sequence 10,6,5,9. I don't think the motor would step 1.8 degree if I just output 10. Would it? I'm at work so I guess I'll try it later.
Thanks. |
